Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 10-04-2011, 12:30 PM
slowtwitch is on a distinguished road
Multiple Contours
Hi Folks, I'm slowly moving along teaching myself Dolphin Cad/Cam. Here is my current dilemma. I have drawn a part, something in the shape of the letter "F".
All the vertical and horizontal areas are .750 wide. The ends of the two horizontal parts of the "F" have an arc (.750" dia.). My problem is when I create a contour, I wind up with 9 contours.
My thinking is that there should only be one contour. Am I missing something ??
pete
Old 10-05-2011, 10:00 AM
andre-dolphin is on a distinguished road
Can you zip the .dra file and attach to a reply here so that we can look at it.
ATB
Andre
Old 10-05-2011, 04:03 PM
ATB
Andre
Thank you Andre, Here's the file...
pete
Old 10-06-2011, 04:53 AM
The problem was there were 25 duplicated lines and arcs. These were drawn on top of each other so it's very difficult to know they exist.
To check go to Edit > Delete duplicates - it will report what it finds.
Also there were two lines across the top of the shape, they weren't identical, one was slightly shorter than the other. I deleted one of them and then used Intersect with Clip items to trim the line to the two vertical lines at each end.
I have attached a modified drawing that has only one contour.
ATB
Andre
Old 10-06-2011, 07:33 AM
Thank you Andre, i'll give it a try tonight
pete
Need Help!- Contours or translate Claude Boudreau BobCad-Cam 6 05-14-2011 11:04 PM
Rhinocam and multiple spindles and or multiple tables? brett gallmeyer Rhinocam 0 02-23-2011 01:30 PM
Contours vs. Profiles? japcas Dolphin CADCAM 3 07-27-2009 07:40 AM
Text Contours (Ellipse) TZ250 Dolphin CADCAM 4 05-10-2008 12:22 AM
CAD/CAM for Instrument Contours????? NardisAmps Musical Instrument Design & Construction 8 01-30-2007 07:33 PM
