Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 09-24-2011, 08:39 AM
dlenardu is on a distinguished road
Dolphin not using zfeed rate on area clear
I'm not sure if something has happend to my post processor or if I'm overlooking something in dolphin but I have two problems.
First: When I do an area clear, dolphin does not use the z-feed rate when it plunges or ramps into the part. It had been doing it on other programs but now it is not. It uses the XY feedrate for everything.
Second: My post process is leaving coordinates off after a tool change. For Example, say I'm drilling a hole with a center drill and then change tools to a drill, it will leave off one of the coordinates and drill in the wrong spot. I have to manually go in and put in the correct coordinate.
Old 09-24-2011, 12:40 PM
John S. is on a distinguished road
Not enough info, what machine, what post processor etc.
Old 09-24-2011, 01:29 PM
It is a Milltronics Partner 1 with a Cent 5 controller. The post processor was a custom one written by dolphin. It had been working fine until recently. However I noticed even on the simulation in the cam program the feed rate is not changing on the Z during the area clear operation. I'm not sure why it started leaving off coordinates in the g-code
Old 09-24-2011, 02:08 PM
Do you have a backup of the post they sent you or an original copy you can substitute ?
Old 09-25-2011, 09:27 AM
Yes, I have the original file for the post processor that they emailed me.
Old 09-26-2011, 06:06 AM
andre-dolphin is on a distinguished road
This sounds like a modality issue, can you send the .cnc file and the post processor please.
support@dolphincadcam.com
ATB
Andre
Area clear avoiding an island? dlenardu Dolphin CADCAM 11 07-25-2011 10:26 AM
Area clear over contour? cboyce Dolphin CADCAM 1 03-11-2010 02:28 AM
Need Help!- 3D Area Clear TZ250 BobCad-Cam 4 02-19-2008 10:29 AM
Dolphin Demo / Dolphin Sales / Dolphin Support Dolphin USA Dolphin CADCAM 0 02-07-2008 12:19 PM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
