Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 07-17-2011, 09:11 PM
mrcodewiz is on a distinguished road
Proper rotary axis usage?
I am trying to do some engraving using my 4th axis but can't quite get it to work right.
The cam program is short - select tool, rotary on (a/y inputting the proper radius of my work piece), go around text, rotary off.
I am using the rotary post processer to generate the mach3 code but when it goes to cut, the text is upside down and reversed. I tried moving the text around to various quadrants to see if that was the reason but no matter where I create the text, using the rotary axis (A/Y) causes it to do this.
Old 07-18-2011, 02:38 AM
John S. is on a distinguished road
A/Y ??
What orientation is your 4th axis ?
I have mine pointing down the bed which then means I use A / X
Try using the Mach3_inc post processor, this will support 4th axis and let us know how that works out.
John S.
Old 07-18-2011, 09:20 AM
Sorry, I meant a/x. It runs along the x axis and I want it to rotate instead of moving the Y. Right now when I run the program the letters go left to right but they are upside down.
I was thinking about it last night and I wondered if maybe my rotation direction in ports/pins was opposite of what it should be. I have used the rotary a lot but never anything that would have mattered if the direction was swapped.
Old 07-18-2011, 09:25 AM
Quite possible and easy enough to do a dummy run to check.
John S.
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 11 05-23-2012 09:31 PM
Tipping rotary haas rotary axis mfpuller Mastercam 1 04-04-2011 10:16 AM
5 Axis CNC with Rotary Axis on Table Shooter7 Commercial CNC Wood Routers 1 09-20-2010 10:33 AM
Rotary head development 3 axis -> 5 axis Mr Helmut Mechanical Calculations/Engineering Design 1 08-03-2010 05:26 PM
Proper size of Z axis rods? simmonsk DIY-CNC Router Table Machines 2 08-19-2006 10:22 PM
