Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 06-12-2011, 12:24 PM
Mark Stehr's Avatar
Mark Stehr is on a distinguished road
Size Help
I am running Dolphin CAM V10 with Mach 3. I just got it along with a Sieg KX1.
The problem is z travel seems fine, but x-y seems tiny.
I believe it is all in metric, I've checked the settings in Mach 3 controller and in the Dolphin CAM. Every time I start CAM a window pops up with options including inch or metric. I always choose Metric, All my read outs are in metric in the controller. In CAM under set up>machine type> mill> it is set to metric.
In the Controller Mach 3, under General Logic Config The G20-G21 box is blank (unchecked) for _ LOCK DRO's to Setup Units. Should this be checked?
One funny thing is the diameter of the cutter changes once the program is loaded. I set the tool info in mach 3 to 6.37mm, and I also set the same info when writing the CAM program and it changes to 161.798mm??? I am using a template program to cut a simple rectangle pocket.
The only other thing I can think of that might be funny is that I have written the program in CAM, Post Processed it from Dolphin CAM so it is now a .ppr file, then I load it from the "My Documents" folder.
I've included pics of Regen and Tool Setting changes before and after the program is loaded. Am I right that it is cutting, but just really small?
Any help is truly appreciated.
Thanks,
Mark Stehr
Name:	Before Loading Program.jpg‎
ID:	136233   Click image for larger version
Name:	After Loading Program.jpg‎
ID:	136234   Click image for larger version
Name:	Regen Screen.jpg‎
Old 06-12-2011, 01:59 PM
andre-dolphin is on a distinguished road
Hello Mark,
I think that this is something in the MACH setup. 6.37 x 25.4 =161.798 which is the inch to metric multiplier.
Maybe because you don't have the G20/G21 switch set it is converting the tool sizes.
This wouldn't explain the small sizes, I don't enough about MACH to point you in the right direction.
Perhaps a post to the MACH forum would be useful.
ATB
André
Newbie- How do I make CAD/CAM size match machined size? RedCoder Benchtop Machines 5 12-07-2010 04:13 PM
Via shape/size and wire size. Drools PCB milling 0 08-14-2009 09:47 AM
Drawing Size and Cut Size Differ - Plasma ADucci LinuxCNC (formerly EMC2) 5 10-05-2007 04:52 AM
Drawing Size and Cut Size Differ - Plasma ADucci Mach Plasma / Laser 0 10-04-2007 08:49 AM
X3 base size or minium bench size kenrc Benchtop Machines 2 02-04-2007 06:50 AM
