Results 1 to 6 of 6
Thread: 4th Axis - Machining from inside out?
    Mar 2011
    I have a simple goround but Dolphin CAM seems to get confused when there are arcs involved. The same profile with 90 degree corners and it works fine but once the fillets are added it seems to invert the profile like it’s trying to machine the arcs from the inside. Any thoughts? I have worked around this in the past by making the arcs their own profiles and running them as a separate step but it seems like this is extra work that should not be necessary.
    Attached Thumbnails Attached Thumbnails 4th Axis - Machining from inside out?-1.jpg   4th Axis - Machining from inside out?-2.jpg
    Attached Files Attached Files
    Feb 2007
    UK
    This happens because of the Feed change plane value.
    With Z zero where you have it, the Feed change plane of .1181 above the zero is not large enough to clear the top part of the job.
    Set the Feed Change Plane to say 0.5" and it works OK.
    ATB
    André
    Mar 2011
    Thank you André. That was probably the only setting I did not try to tweak sorting through this!
    Dec 2007
    Usually how it works.
    Mar 2011
    One more question with regard to zero André. I set the datum in CAD and save the drawing, as soon as I go to CAM it puts the Z Zero in the center of the drawing where you see it. Any reason it does not hold the zero datum from CAD to CAM?
    Mar 2011
    Scratch that. I now see you have to have the datum set on a contour or it will not hold when you go to CAM.
    1. 5-axis vs 3-axis machining rigidity
      By Gabe Newell in forum General Metalwork Discussion
      Last Post: 03-15-2011, 11:54 AM
    2. Problem- 4th axis machining
      By jayroach in forum Mastercam
      Last Post: 11-04-2010, 10:03 PM
    3. Replies: 3
      Last Post: 05-28-2010, 05:02 PM
    4. 4th Axis machining
      By R.DesJardin in forum Tormach Personal CNC Mill
      Last Post: 02-06-2009, 05:03 PM
    5. 4th axis machining
      By senor J. in forum Visual Mill
      Last Post: 10-22-2004, 04:10 PM
