Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 03-24-2011, 03:13 PM
Minna is on a distinguished road
Help on program for volume(mass) of shapes
As far as i know, Dolphin doesn't have any function to figure out the volume of objects drawn.
Anyone know a program i can get/purchase to figure out this information for my drawings? Hopefully a cheap program because this is all i want from it at this time.
Thanks,
Tony
Old 03-24-2011, 04:10 PM
M250cnc's Avatar
M250cnc is on a distinguished road
I would guess that unless you can produce a SOLID part with Dolphin you cannot use any other program to get that info either
Phil
Sent from my HTC Desire using Tapatalk
Old 03-25-2011, 11:40 AM
andre-dolphin is on a distinguished road
PartMaster has a Static Cacls module that gives you things like perimeter, area (volume) etc.
It uses the Hatch routine but comes up with a bunch of numbers instead of cross-hatching.
To use this choose Hatch and from the options toolbar select "Static Calcs".
The area must be enclosed, the hatch routine works in very similar manner to creating a contour eg, trace around the periphery.
When the hatch boundary has been enclosed it asks about islands, if there are any then trace round them, if not hit click No.
The results will be shown on screen - quite a lot of numbers. The actual details are held in a file called Calc.txt - saved in the Documents folder.
This can be incorperated into the drawing using Text > Import file.
Hope this clear.
ATB
André
Problem- No Extrude for Volume Milling sebastian_dogar PTC Pro/Manufacture 8 03-29-2011 05:29 AM
Beep Volume musall37 Haas Mills 5 03-09-2010 03:15 PM
Air Air Volume bdring Laser Engraving & Cutting Machines 3 08-17-2009 06:57 PM
Need Help!- Looking for a low volume CNC vendor sn96 General Metalwork Discussion 2 01-21-2009 03:06 PM
Volume mace PTC Pro/Manufacture 33 10-20-2003 11:44 PM
