| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
| Hello, If you only use Mach3 and Dolphin I would just change the IJ Mode setting in Mach3. Even if you use other CAM packages it is very easy to change the IJ Mode in Mach3 and if needed you can change it back just as quick for a different software. The setting has only 2 choices Abs(absolute) or Inc(incremental) and is easy to change with a radio button selection. I believe you will find it under the Config tab, general config. if I remember correctly.
__________________ Regards, Wes Last edited by metalworkz; 07-08-2010 at 06:31 PM. Reason: spelling |
| Yes, it is very simple to change the IJ mode in Mach3. It has worked for me in the past with files given to me by other people. The problem is that I have the usual extra arcs that come with having the wrong mode when I'm using Incremental but get "radius to end of arc...." error in Absolute mode. I'm assuming that the post processing code is generated by DCAM using absolute but something does not work properly. I'm new and don't know what questions to ask to get the answers to make it work properly. Maybe I don't have the Mach3 post processor setup correctly in CAM? I'm not sure. It's probably another one of those things that is right in front of me. Here is my code that is generated: ( Produced :- 14:42:53 Thursday, July 08, 2010 ) ( CNC File :- clamp ) ( Post Processor :- M_MACH3 ) ( Part Number ID :- ) N5G00G20G17G90G40G49G80 N6G49 N7T1M06 ( End mill ) N8G00G43Z1.9685H1 N9S500M03 N10G94 N11X-0.125Y0.0 N12Z0.125 N13G01Z-0.5F20.0 N14X-0.125Y0.375 N15G02X0.125Y0.125I0.125J0.375 N16X0.375Y0.375I0.125J0.375 N17X0.125Y0.625I0.125J0.375 N18G01X0.6349Y0.625 N19G02X0.4896Y-0.1254I2.4989J-0.1254 N20X2.4989Y-2.1347I2.4989J-0.1254 N21X4.5082Y-0.1254I2.4989J-0.1254 N22X4.3628Y0.625I2.4989J-0.1254 N23G01X4.875Y0.625 N24G02X4.625Y0.375I4.875J0.375 N25X4.875Y0.125I4.875J0.375 N26X5.125Y0.375I4.875J0.375 N27G01X5.125Y0.0 N28G02X5.0Y0.125I5.0J0.0 N29X4.875Y0.0I5.0J0.0 N30X5.0Y-0.125I5.0J0.0 N31G01X3.9873Y-0.125 N32G02X4.2373Y0.125I3.9873J0.125 N33X3.9873Y0.375I3.9873J0.125 N34X3.7373Y0.125I3.9873J0.125 N35X3.7407Y0.0835I3.9873J0.125 N36G03X3.7582Y-0.1254I2.4989J-0.1254 N37X2.4989Y-1.3847I2.4989J-0.1254 N38X1.2395Y-0.1254I2.4989J-0.1254 N39X1.257Y0.0835I2.4989J-0.1254 N40G02X1.2604Y0.125I1.0104J0.125 N41X1.0104Y0.375I1.0104J0.125 N42X0.7604Y0.125I1.0104J0.125 N43X1.0104Y-0.125I1.0104J0.125 N44G01X0.0Y-0.125 N45G02X0.125Y0.0I0.0J0.0 N46X0.0Y0.125I0.0J0.0 N47X-0.125Y0.0I0.0J0.0 N48G00Z1.9685 N49M09 N50M30 % It should look like this: ![]() Here are some screen shots of what is going on in Mach3: ![]() -------------- |
| Here are some pictures of tests I just did on a simple shape. I drew the same basic shape with the Incremental and Absolute button in each position in the D-CAD program and did not see any change. Here are some images to help see the trouble. It looks like it is more than just the IJ mode... Basic Shape: ![]() Incremental: ![]() Absolute: ![]() I'm guessing the Absolute is the correct mode but the arcs are wrong. |
| Hello, Which post processor are you using to create the program files? M_MACH3.ppr?? In the CAM side click the 'Execute' tab along the top and then 'Post Process' in the drop down menu. You can select the post processor in drop down menu in the text box marked 'Post Processor name'. I have been using the M_MACH3.ppr since I started using Dolphin with Mach3. I did have some problems with the unit of measure conflicting between Mach and DCAM at first, but don't recall any problems with the arcs etc.
__________________ Regards, Wes Last edited by metalworkz; 07-08-2010 at 11:04 PM. |
| Hello, Not sure why you are having problems, attached zip file contains an example job, similar to yours with a Word doc showing screen images and the post I am using. Mach config set to Abs arcs. Try the attached post. ATB Andre |
#10
| That's my guess, they must have been corrupt. It's all I changed and it's working now. Thanks again everyone for the help. Here is a picture of my first part. It is not overly impressive, just some clamps to hold my small router for engraving. (the blue nylon) |
#12
| The problem has arisen because a Guy called Steve Blackmore who uses Absolute arcs supplied a post file to Dolphin and this was released. Most people use Incremental arcs. There is a file kicking about that's called Mach3inc.ppr, this is for incremental arcs. John S. |
| Absolute vs. incremental encoders | sinha_nsit | Fanuc | 20 | 10-11-2009 04:38 PM |
| Problem- Incremental Vs Absolute mode | chilly2k | Mach Wizards, Macros, & Addons | 4 | 03-06-2009 04:54 PM |
| Need Help!- Subroutine and Absolute/Incremental | VWbmx | G-Code Programing | 15 | 02-22-2009 01:09 PM |
| Absolute or Incremental | mikede | Haas Mills | 1 | 02-03-2007 05:02 PM |
| Absolute and Incremental | ACME | G-Code Programing | 3 | 09-04-2004 05:45 PM |
