Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 06-03-2010, 07:48 PM
Astroguy is on a distinguished road
Need Help
I am having trouble post processing to Mach3. I am trying to cut an A-frame and in Dolphin cam it runs fine in simulation but when I open it in Mach3 the arcs are circles. I have tried every thing I know HELP!!! I have attached the file but changed the extion to doc instead of txt.
Old 06-03-2010, 08:00 PM
harley4ever is on a distinguished road
Whats the name of the ppr you are using
Old 06-04-2010, 04:18 AM
andre-dolphin is on a distinguished road
This sounds like the config setting in Mach3.
In Mach select Config from the main menu then select General Config, look at the second column of entries and find the section on IJ mode. Change it to the other option from the current setting and re-load the gcode file.
If this doesn't cure it let us know.
ATB
Andre
Old 06-04-2010, 08:00 AM
ATB
Andre
I tried that and all it does it change the size of the circles.
Old 06-04-2010, 08:02 AM
M MACH3.ppr
Old 06-04-2010, 09:10 AM
They the mach 3 inc post. If I remember right, I had trouble with the one you tried as well.
Old 06-05-2010, 03:52 PM
Hi guys not to be a pest buy I am still looking for help with this problem. I have attached the Dolphin drawings, I exported it as a dxf.
Old 06-05-2010, 04:21 PM
Did you try what I already mentioned?
Old 06-05-2010, 04:40 PM
You mean this?
"They the mach 3 inc post. If I remember right, I had trouble with the one you tried as well. "
Not quite sure what you mean?
Old 06-05-2010, 05:27 PM
Meaning the post that you have is probably outdated and there has been a revision
  #11   Ban this user!
Old 06-05-2010, 06:40 PM
John S. is on a distinguished road
Unzip and put this file into the Applications data folder inside Dolphin Partmaster.
http://www.stevenson-engineers.co.uk...ch%203_inc.zip
  #12   Ban this user!
Old 06-05-2010, 07:46 PM
Thanks I will give it a try. I one I downloaded was dated 6/2010 but i will try this one.
