Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 03-25-2010, 10:04 AM
ChetR is on a distinguished road
Problem importing bmp file
New to Dolphin cadcam...
I'm trying to import a bmp graphic of a solid light gray tree onto my work surface, but I can't see it after importing.
If I try to import it again, the program prompts me that it is already there.
So where is it?
How do I see it?
Old 03-25-2010, 04:11 PM
harley4ever is on a distinguished road
I havent used that feature much but if you look in the help section or whats new it should explain it. I think you import the bitmaps and then trace over.
Old 03-25-2010, 04:29 PM
Thanks for the input, but if I can't see it, it would be pretty hard to trace, yes?
I tried the help files first, but wasn't able to discover an answer...
Old 03-25-2010, 04:46 PM
This is from an earlier thread.
Select import choose your image then click the image icon on your tool bar (the green cactus) which will bring the image to the work area then click to drop it. You can also set the scale in the properties dialog box.
Old 03-25-2010, 05:59 PM
I'm not seeing the green cactus image icon...
But I downloaded the program using the Intermediate Level settings...
A search of Help for 'cactus' or 'image icon' produced no results...
If I can now find that icon, I'll probably be in good shape.
Any idea how to make the 'cactus' appear?
Old 03-25-2010, 06:21 PM
You can right click anywhere on the menu and click customize. On the left menu double click image. It should appear then.
Old 03-25-2010, 09:17 PM
Bingo!
I was finally able to find the two cacti icon, and cause the image to appear.
Thanks for your patience in helping me find the tool!
I can't wait to actually manipulate the image after a decent night's sleep...
Chet
Old 03-26-2010, 06:51 AM
andre-dolphin is on a distinguished road
Hello Chet,
Rodney asked me to produce a video showing the bitmap feature.
I have uploaded a short video to :-
www.dolphin2.myzen.co.uk/flash/bitmaps.zip
Unfortunealtely there is no sound as my sound card has gone AWOL.
Please bear in mind that the image must be a .bmp file and that the image can't be accessed directly, it's only use is for tracing over. In the video I used the curve fit command but you could use the lines/arc/ etc.
If you use the curve fitting routine - look at the help messages at the bottom of the screen, this will guide you as what to do next.
ATB
Andre
Old 03-26-2010, 09:08 AM
Andre, thank you for your effort.
(And a thanks to Rodney for suggesting it!)
BUT, I'm having trouble playing the un-zipped files.
There's 3 files in the folder:
bitmaps.html 1 kb
bitmaps.js 1 kb
bitmaps.swf 4,548 kb
Nothing happens when I click any of the above.
I'm sure I have Flash, and any number of other players, but when I double-click on the .swf all I get is a spyware check...
(And, yes, it passes)
TIA, Chet
Old 03-26-2010, 12:32 PM
Hello Chet,
You just need to double click the .html file, this calls up the shockwave flash file.
It might be somehting to do with your internet setting as Windows probably thinks you are trying access the internet from a non-secure source.
You may also have to disable any fire-walls/virus checkers that you have.
ATB
Andre
  #11   Ban this user!
Old 03-26-2010, 12:39 PM
Worked ok for me although I caught myself watching it twice since it doesnt stop at the end, just auto starts over.
Old 03-26-2010, 12:41 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
it would be easier and more accurate to trace the image in inkscape , save it as a dxf then import it into dolphin
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Newbie- igs file importing into mastercam hedgehog23 Mastercam 7 11-22-2009 11:13 PM
Problem importing DXF to Plasmacam Ironworks PlasmaCam 3 04-22-2009 02:35 PM
Importing Rhino File buggie Mastercam 2 04-13-2009 12:51 PM
Importing .IGES file into SW 2007 2_jammer Solidworks 3 12-28-2007 11:23 PM
Importing a DXF or HPGL file wantsout Kellyware CAM 2 10-10-2007 03:54 AM
