Deleteing stuff
Results 1 to 2 of 2
Thread: Deleteing stuff
    Sep 2016
    Default Deleteing stuff
    Say you have a drawing and you want to delete a bunch of items at the same time. Is their a way to do it without clicking on each individual item with that d@mn little box with the eraser? Can I just make a box around it and delete all of it like in AutoCad? How? This is driving me nuts.
    Moderator
    Feb 2007
    UK
    Default Re: Deleteing stuff
    Yes, use the Select icon from the drawing ops toolbar - it's the Arrow with Select beneath it, between the Query and Delete icons.
    Drag a box around the selection - only items fully inside the box with be selected - then press delete on the keyboard.
    Also, when you have selected some items, the cursor will change to a box with a plus/minus sign next to it. Use the cursor to select / deselect other items whether they are part of the original selection or not.
    You can also use the Edit > Delete All wizard from the top menus to delete many items at once.
    ATB
    Andre
Deleteing stuff
Deleteing stuff
