Need Help! Tool change goes through part
Results 1 to 3 of 3
Thread: Tool change goes through part
    Sep 2016
    United Kingdom
    Default Tool change goes through part
    HI there I am using Dolphin Cam turning module the problem i have is when i simulate the tool path the tool change goes through the part.
    After post processing this runs OK on the HAAS SL20 but looks wrong when checking the tool paths in the software any ideas tried all sorts of setting combinations.
    Kind Regards Mark
    Attached Thumbnails Attached Thumbnails Tool change goes through part-tool-change-simulate-problems-jpg
    Jul 2010
    Default Re: Tool change goes through part
    Did you solve this? You're geometry/profiles are wrong. You should see the complete part in the cam, not half...
    Feb 2007
    UK
    I beleive my colleague Michael sorted this out with mods to the post.
    ATB
    Andre
