Turning simulation throws exception
Results 1 to 5 of 5
Thread: Turning simulation throws exception
    Jul 2009
    Default Turning simulation throws exception
    I build a profile using DCAD, set up the NC profiles, and go to the turning module.
    There, I setup the machine type, all tools, and turning operations, goto, etc.
    The Run shows the resulting cut.
    Then I would like to run a 3d simulation.
    I select Execute | 3d Machine tool Simulation, and then use ST_Lathe.ppr
    DCAM replies "The Simulator data has been created."
    I click OK to run the simulation, but instead, mwSimulator replies
    "Error decoding tool select command line.
    TURN/TOOL/SELECT/1, TURNING TOOL
    System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid...
    and a whole bunch of Microsoft VisualBasic exception information.
    How to get a simple simulation to run?
    This doesn't happen when running a milling simulation.
    Feb 2007
    UK
    Default Re: Turning simulation throws exception
    Hello,
    Can you send the .cnc file you are suing to michael@dolphincadcam.com
    ATB
    Andre
    Jul 2009
    Files were sent. Have you any idea why the 3d lathe simulation fails, while the mill simulation example works fine?
    Feb 2007
    UK
    Hello
    Sorry for the mess up, can you send the file to me please, Michael is away from the office at the moment.
    andre@dolphincadcam.com
    ATB
    Andre
    Jul 2009
    Files forwarded to you. Please take a look.
    Thanks.
