Page 5 of 5 FirstFirst ... 2345
Results 49 to 56 of 56
Thread: Help setting up VFD
  1. #49
    Jun 2010
    New Zealand
    Hi Mactec
    It looks as if your trick did the.. trick?
    I rewired the AV_out G back to the power supply instead of the VFD and I started to get readings!!!
    I had a little play with the Spindle SRO slider and the volts changed as they should. Thankyou.
    Unfortunatly It didnt move the spindle though...sigh..
    Craig at CT checked the VFD parameters/inputs for me and they are ok so thats good too.
    So it looks like Im not getting 24v out of the BOB from D_OUT D16 to the VFD B5 Terminal to give it the run command.
    Is D16 even +24v out?
    Which one is +24V out?
    I'm wondering if I should be using CP1 (+v) and CP2 (-v?) instead, as on Hui's spindle wiring diagram on the BOB pdf.
    Help
    Attached Files Attached Files
  2. #50
    Jan 2005
    firstyear
    First have you had the VFD & spindle running from the key pad control, you have to do this first
    Once you have that part set up, you then change one setting, for Terminal control
    You only get 0-10V out of the Bob for the control, this is normal
    Mactec54
  3. #51
    Jun 2010
    New Zealand
    Hi Mactec
    Yes I've had the spindle running through the pad and all was ok, it's just when I tried to switch it to mach/bob control that I've run into problems..
    Golly - Now i'm really confused.. maybe I need to backtrack
    As I understand it -which is obviously wrong -
    * For spindle Speed control (AV_OUT) I'm using an independent 10v p/s going to the BOB ( G & Vin) then on to the VFD (Vout to VFD T2)... As apparently both the BOB and VFD don't produce 10V out?
    * The Run command (spindle on/off) on the VFD B5 Terminal is given by via 24V instruction from D_OUT D16
    * The BOB pdf shows 30V out put via D16 and also indicates 24v out of CP1 & CP2 relays - Hui has pictured a VFD with start/stop coming from CP1 & CP2?
    I'm now guessing all are wrong and I'm confused as to where to start.
  4. #52
    Jan 2005
    firstyear
    Your drive does have a +10V output that you could of used for the Bob & would of wired
    to the Bob the same way as you have with the remote 10V supply Pin 3 10V+ & Pin 1 Common, these would of wired & done the same job as the remote 10V supply
    I would contact your supplier about what you have to do with the 24V, what information I have on the drive, I can not see the information that is needed to make the correct conection
    The Bob & Mach is working correct by what you said in your post, It may be just a parameter change so you can use the 0-10V to control the drive
    0-10V is the norm to control most VFDs so I'm sure there is a way with your drive to do this
    Just checked the B5 is a 0 to 24V so you should be ok most likely just some parameter to change
    Mactec54
  • #53
    Jun 2010
    New Zealand
    Thanks Mactec
    I'll rewire using the T3 terminal on the vfd like you said - Damn I had a gut feeling that the VFD produced +10V through T3, but I must have misunderstood some earlier instructions..
    That's ok.
    CT suggested running a contact between B2 and B5 for the run command, but this was in lieu of using D_out D16 from the BOB.
    If I do this then I'm guessing that I wont be able to start stop the spindle via the bob/Mach?
  • #54
    Jun 2010
    New Zealand
    DMM_TECH TO COMMANDER SK SETUP INSTRUCTIONS FOR MACH3- -WORKING SWEET!!
    Hi Guys we cracked it!
    It was stupidly simple in hindsight and works beautifully.
    Thank you Mactec, Hui at DMM and Chris at Control Techniques for all your help.
    Hope this helps someone else in the future as DMM & CT is a sweet combo....
  • #55
    Jun 2010
    New Zealand
    wow 40 posts, 20 emails and 5 emergency calls from Mactec; and I've gone from a newbie to a very proud cnc owner. Sweeeeet!
    Now I'm going to build a space shuttle
  • #56
    Jan 2005
    firstyear
    That's very cool, I'm glad we could help you acheive your dream, to have a machine running & making parts for your projects, Have a great trip to Milan & that your project presentation is successful to
    Mactec54
  • Page 5 of 5 FirstFirst ... 2345
    1. How setting tools and setting offset
      By John246 in forum Sharp CNC
      Last Post: 10-08-2012, 03:38 AM
    2. Setting Up a New X4 Plus
      By heycorey in forum Syil Products
      Last Post: 07-24-2009, 04:00 PM
    3. Need Help!- Setting Z 0
      By ErnieD in forum Tormach Personal CNC Mill
      Last Post: 06-29-2009, 09:40 AM
    4. Setting z
      By bbergami in forum G-Code Programing
      Last Post: 10-01-2006, 09:21 AM
