Dmm Dyn4 pmdx126 ess control build - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 33 of 33
Thread: Dmm Dyn4 pmdx126 ess control build
  1. #25
    Feb 2016
    Default Re: Dmm Dyn4 pmdx126 ess control build
    • According to the website they are
    • Single/Three-Phase 110~240VAC ± 10% 50/60Hz input
  2. #26
    Gold Member
    Jan 2005
    Quote Originally Posted by RootbeerFLHX View Post
    That is correct for the Dyna4 Drives
    Mactec54
  3. #27
    Mar 2003
    So they can be run from 120V single phase?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #28
    Feb 2016
    Quote Originally Posted by ger21 View Post
    Yes.
  5. #29
    Jul 2010
    Yes.
    Not sure for 120v. I had wired mine direct and measured the draw then added 10% and used a D curve which allows a 10 times spike for the rectifier and capacitors to charge.
  6. #30
    Feb 2016
    Quote Originally Posted by LtDan View Post
    Ok. When you measured your draw were you running the servo on the machine, or just sitting at idle?
  7. #31
    Mar 2003
    I found a good deal on EMI filters, if you need any.
    (1pcs) NEW!! SCHAFFNER - FN610-3-06 - POWER LINE FILTER USPP FN610306 | eBay
    He charges $5 shipping for as many as you want. When you purchase, it charges $5 each, but he refunds the extra shipping.
  8. #32
    Jul 2010
    I locked the shaft with an old pulley and a big pipe wrench lol don't try this unless your certain you can hold it. I saw 7.4 amp on 248v then the drive errored. I am using 32amp breaker on 240v for 3 750w drives.
    Fyi I used the dmm drive software to command the motor in test movement mode. You can just do the math and get your answer.
    It is probably gonna be close to double.
  9. #33
    Nov 2017
    Very nice just curious, what model/PN Gould fuse holders did you use?
