Dyn2 losing EEPROM settings - Page 8
Page 8 of 9 FirstFirst ... 56789 LastLast
Results 141 to 160 of 164
Thread: Dyn2 losing EEPROM settings
  1. #141
    Member mactec54's Avatar
    Jan 2005
    Default Re: Dyn2 losing EEPROM settings
    Bl@ckrat
    Good to hear from you, how do you have your power supplies wired, into your system, some photos would be good
    Mactec54
  2. #142
    Mar 2014
    I was running my mill this weekend for the first time in a few months and seem to be loosing EEPROM settings too.
    It has happened a few times in the past too. Can Mactec or someone explain the way I should be grounding my servos?
    Not sure if it is the problem or not but I have all grounds going to a common earth (the enclosure). The servos all had 4 wires, 3 for the phases and 1 for earth?
    Here is some images:
    Dyn2 losing EEPROM settings-1-jpg
    Dyn2 losing EEPROM settings-2-jpg
    Dyn2 losing EEPROM settings-3-jpg
    Sorry for the dodgy drawing,
    Does this look ok, any suggestions?
    Cheers
  3. #143
    Jan 2005
    _Phil
    Your wiring looks ok, you should contact Dmm and see if they have an answer to this problem, I have tried everything to try and make this happen, I even created a short circuit directly to the drives and EEPROMS still stayed the same, where your grounds terminate, is it unpainted in this mounting area, so the Ground wires get a good metal to metal contact
    where are you from I see you are using 240v
    Mactec54
  4. #144
    Mar 2014
    Ok thanks for the reply, ill send an Email tomorrow, cheers.
  5. #145
    Jan 2005
    Quote Originally Posted by _Phil View Post
    Which country are you from I see you are using 240v
    Mactec54
  6. #146
    Mar 2014
    I'm in Australia.
    Its strange, the system will work flawlessly for a month sometimes and then some days like today reset random a few times in a couple of hours....
  7. #147
    Jan 2005
    I'm in Australia.
    Are you just having to just reset, by power off, or do you have to reset the Parameters to the EEPROM
    If it's just a Reset, then you may just have the acceleration or velocity set just a little to high, your settings may be right at the max for the power supplies/motors your are using
    Mactec54
  8. #148
    Mar 2014
    It is usually the Gear_num that changes. I have it set to 1000, I noticed in one of your post you said 500 is the best setting.
    Could that cause the problem?
  9. #149
    Jan 2005
    No but it should be set at 500 for step/dir use, with setting it at 500 you will have to reset your steps/per, when using a 500 Gear number, this gives you 2000 Steps Per Rev
    Mactec54
  10. #150
    Mar 2014
    Yeah, when i get time I might re-calibrate at 500 just to see
  11. #151
    Jan 2005
    It's not going to solve the problem, your motors will run smoother though, it seem that the users that have had this problem most are using 220/240v power supply
    I can't see how you have your power supplies connected, did you balance each power supply to have the same output voltage ?? before connecting them together
    Your Grounds on the power supplies are fine,if there is no paint under the terminal mounts
    Mactec54
  12. #152
    Mar 2014
    Hmm no I didnt balance, how do i do this? Multi-meter on the output + - and make sure both are 48v? I thought it would be set from DMM.
    Here is a couple of pics up close, not sure if you can see.
    I have 240v come in the side of the enclosure, it runs through a breaker, then up to the 2 power supplies, the two + wires from the power supply's join then go to the BOB then distribute to the 3 drives. the two - wires from the power supply do the same.
    Thanks for the help.
    Attached Thumbnails Attached Thumbnails Dyn2 losing EEPROM settings-1-jpg   Dyn2 losing EEPROM settings-2-jpg   Dyn2 losing EEPROM settings-3-jpg
  13. #153
    Jan 2005
    Yes you should disconnect the +/- and adjust the trimpot, next the the Green Led, you can run them up to 50v ,have both at the same setting, I also don't know what motors your are running as there system can draw up to 20Amps, so you don't have enough output from the 2 power supplies, they normally have 3, for most systems like this
    You should always twist your wire pairs where ever you can, this will help with any noise, which you will have, all systems like this do, when you can't twist wires then you should use shielded cable
    Mactec54
  14. #154
    Mar 2014
    Ok ill try that thanks. yeah i did ask about the power because on the documentation it says "48Vdc, 21amp" but my 2 power supplies together only 14 amp.
    I was told this was enough, I bought this as a kit BOB, power supplies, drivers, motors and cables.
    I am running 3 92GM-DHT-72 7.2nm high torque motors. Do you think 14amp is sufficient? when its running it runs well.
  15. #155
    Jan 2005
    If your motors are 750w then you should have 3 power supplies, they would be border line with the 2 power supplies, which may be why you can get a Reset Fault, if you don't use a lot of rapid moves you may be good with just the 2 power supplies, if you decide to use 3 then you can mount them on their side, so you would still have enough room in your cabinet
    Mactec54
  16. #156
    Mar 2014
    I might get a 3rd then just for peace of mind, i have had resets in the past.
    Im waiting to hear from DMM about the Gear_num changing.
  17. #157
    Mar 2014
    Hey Mactec, I got my 3rd power supply today. It is the same as the other two 48v 7.1a.
    I's it definitely ok to parallel 3 power supply's? Came across a few articles online saying that it shouldn't be done?
    Thought I should check here first.
  18. #158
    Jan 2005
    As long as you balance them to have the same output, there is no problem, it's amazing how much confusing information there is out there, of cause ( 1 ) Big power supply is the best, the cost is a lot more as well as the shipping, that is why most use 2 or 3 this way, for ease of wiring I made these 8 into 2 power terminal blocks
    Attached Thumbnails Attached Thumbnails Dyn2 losing EEPROM settings-hpim3069-jpg
    Mactec54
  19. #159
    Mar 2014
    Thanks for clearing that up mate.
  20. #160
    Dec 2007
    You get what you pay for ,there JUNK!!!!!!!!!!
