Go Back   CNCzone.com-The Largest Machinist Community on the net! > General Maintenance > DIY Discussion
DIY Discussion Discuss anything from how to install a simple light fixture, wiring sub panels, shop air, water, vacuum etc
  #13
Old 02-02-2012, 03:16 PM
Al_The_Man's Avatar
I have distinct dislike of wire nuts, they were banned in the UK a long time ago.
If I have a few conductors to be terminated that large, I usually use a terminal block, in the case of grounds you can get common ground buss bar as is used in panels, neat, safe and efficient.
Especially grounding items such as welders.
  #14   Ban this user!
Old 02-02-2012, 04:40 PM
will gilmore is on a distinguished road
Are you recommending this style of terminal block? I've used these in electronics projects but it is ok for distribution?
Or this looks like it would work for grounding:
What are the professionals using?
  #15   Ban this user!
Old 02-02-2012, 04:44 PM
underthetire is on a distinguished road
Originally Posted by will gilmore View Post
I've never heard anything about accounting for bends in the conduit. Do you have any more information on that?
it's all in the NFPA 70E handbook. Not sure if its available on line or not. The book I have is about 4" thick. It all boils down to more bends= larger conduit for the same size wire, if your close to the fill capacity anyways. Just like you cant run SO cord or romex through conduit, its all about heat dissipation on the conductors.
Old 02-02-2012, 06:17 PM
Al_The_Man's Avatar
That's the type of ground bar or a variation, the live terminal block is similar but has an insulated mounting.
  #17   Ban this user!
Old 02-02-2012, 06:37 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
"Ugly's" has a good condensed code book, with most of your answers for a few bucks. I think I even saw it at H' Depot. As far as running your conduit, there are other options. I got the 4x4 inch trough with the flip top lid for the bulk of the wiring out of a new three phase service. Ran it down the middle of the shop. This way, drops and future changes are easier.
Jim
  #18   Ban this user!
Old 02-03-2012, 05:35 PM
Can you post a link of what you are thinking about?
Old 02-03-2012, 06:08 PM
Al_The_Man's Avatar
The Ground bar is similar to what you would have in any distribution panel.
For power there are these.
http://www.automationdirect.com/stat...edisonepdb.pdf
http://www.weidmuller.ca/system/file...ion_Blocks.pdf
  #20   Ban this user!
Old 02-03-2012, 08:30 PM
Ah yes. I have seen those before. Thanks.
  #21   Ban this user!
Old 02-06-2012, 09:06 AM
Ok. I think this is really my last question:
My Tree originally had three hot wires coming in plus a ground. In side the cabinet there is a 240/120 transformer to power some of the components (spindle speed motor, coolant/lube pumps, light, etc).
1. Can I remove the transformer and bring in a neutral to get 120V into the cabinet?
2. Does the neutral need to be broken at the disconnect? My reading of the code says it does not because it is a grounded conductor.
Thanks again.
Will
  #22   Ban this user!
Old 02-06-2012, 09:48 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I have been using this type connector in my shop.
McMaster-Carr
I really like these. I too have a dislike for wire nuts.
I also chose to run the blue flex conduit with the plug in style connectors for all my lighting. That makes short wok of it.
I am using all 3/4" conduit on the walls, but almost went to 1". It would have been better I think.
Lee
  #23   Ban this user!
Old 02-06-2012, 10:02 AM
McMaster-Carr
Interesting but I need to connect #8 wire and those only go to #12.
Old 02-06-2012, 10:03 AM
Al_The_Man's Avatar
Will
You can bring in a neutral
The neutral should never be switched or fused.
Wouldn't it be easier to bring in 240 and use the transformer?
Shop Wiring Question BanduraMaker DIY-CNC Router Table Machines 8 03-13-2011 02:27 PM
Problem- job shop jeanro49 GibbsCAM 0 10-30-2010 11:03 AM
Need Help!- OLD SHOP BOT PR shovelhead3d General Electronics Discussion 1 11-21-2008 03:20 PM
Shop wiring advice 91bird General Electronics Discussion 11 10-16-2008 11:47 AM
Best cad cam for our shop??? mt92 General CAM Discussion 3 10-16-2005 02:02 AM
