You could always fasten the pipe down with cross-dowel fasteners in the mdf. You could also try a reverse angle on your mdf and use aluminum angle instead of the pipe.
Hi everyone,
Been reading this site for quite some time now and its time for me to build my router. I have based it around a JGRO router as I dont have enough tools IMO to do a full torsion box setup properly like a Joe's 06 or similar.
One thing i never like on the JGRO was the way the X rails were mounted, with no support all the way along them. I think that the design also puts so much weight on the top bearings and not much on the bottom ones. I plan to run them on top and under the rails in dual rail config.
I plan on using 2 x pieces of 18mm MDF (yea, im an Aussie :P) with a 35-45 degree angle cut on either side to form a valley for my steam pipe to sit in.
I will need to mount the pipe to these pieces of MDF so it stays rigid across the whole length, what is the be4st way to do this? I was thinking about drilling holes through the pipe and then running a screw into the MDF, but not sure how this will go.
Once the rails are mounted up t the MDF and are parallel along the entire length I will level the rails out with the end plate adjustments. The plates will be tied together through the center with some all thread to keep them from separating any.
I havnt started sketching it up yet but I want to use a gantry design similar to that of Joe's 06, but not quite as complex.
Here is a quick sketch I done up, dont mind my booty fab drawing skills
Any ideas are welcome aboard, I have my HobbyCNC 305oz kit here but the machine itself is not started yet, so can change that up a bit. Will be buying some MDF sheets next week and some other goodies.
John
