Results 1 to 3 of 3
Thread: Facing Aluminum Box Tube w/o Distortion
    Jan 2008
    Hello,
    I am starting a medium sized gantry router/mill build with aluminum box tube extrusions, and I would like to square/flatten them with a flycutter on my 10x50 (Table size) universal mill. What I am unsure of is how to hold them firm enough for cutting without distorting them when I clamp them down. Any helpful tips or suggestions would be appreciated.
    Regards,
    Raymond
    Apr 2007
    Quote Originally Posted by raymondg View Post
    Hello,
    Regards,
    Raymond
    Low profile toe clamps might be best suited for this application. They are not especially cheap though. They will allow clamping along the sides so that no tooling is above the surface being flycut.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jan 2008
    Thanks CarveOne, that's just the kind of solution I was looking for. I don't think the price will be too bad. I figure I can clamp stops on one side of the the extrusion using aluminum scrap and my t-bolt clamps, and use a few of the camming clamps opposite them on the other side. Time will tell if I can get by with just 4 or so, or if it makes more sense to buy a whole set of 10 like Enco sells. I guess I will need to get the big ones to fit my t-nuts, or machine special t-nuts to hold the smaller sizes.
    Raymond
  1. Need A Quote- Aluminum tube
    By m-134b in forum Employment Opportunity
    Last Post: 12-28-2009, 10:01 AM
  2. pressing aluminum into an aluminum tube
    By Fishin_Rod in forum Mechanical Calculations/Engineering Design
    Last Post: 07-01-2009, 01:23 AM
  3. Facing aluminum stock- tool to use
    By leberen in forum General Metal Working Machines
    Last Post: 08-05-2006, 11:02 AM
  4. aluminum table tube
    By dgalaxy in forum DIY CNC Router Table Machines
    Last Post: 05-09-2005, 08:23 AM
  5. Where to find Aluminum Tube
    By NeoMoses in forum General Metalwork Discussion
    Last Post: 01-22-2005, 04:54 PM
