Results 1 to 3 of 3
Thread: Electronics...
    Jan 2010
    Switzerland
    Electronics...
    Hello,
    I've been visiting these boards since the last 6 months regularly, and I'm pretty convinced that I'm finally ready to built my own router table.
    The design is going to be a basic mobile gantry, 3 axis cnc (MDF based). The design will 20" * 30". I'll use Mach 3 to control it. The problem I'm having is concerning the electronics, like I live in Europe I simply don't have access to the famous Geckodrives
    I was thinking of buying here:
    http://www.slidesandballscrews.com/ (If you got good alternatifs, don't hesitate posting them)
    What I'm thinking of:
    Breakout Board:
    Uniport (Click for information) ($81.00)
    • Five optical isolated inputs with internal power jumpers.
    • X/Y/Z/A buffered outputs with 30mA drive capacity.
    • Three 16A @ 250V AC Single pole relays.
    • Charge pump protection on all outputs and relays.
    • USB powered, only consumes 250mA with all relays energised.
    • Optional 5 volt power connection.
    • LED indicators for power, charge pump, power save and all three relays.
    • Uses standard parallel cable and A to B USB cable.
    Stepper Driver (3x): ($72.00)
    PM752 Microstepping Driver (Click for information)
    • High performance, cost-effective
    • Supply voltage up to +75 VDC
    • Output current up to 5.2A
    • Self-adjustment technology
    • Pure-sinusoidal current control technology
    • Pulse input frequency up to 300 KHz
    • TTL compatible and optically isolated input
    • Automatic idle-current reduction
    • 16 selectable resolutions in decimal and binary, up to 51,200 steps/rev
    • Suitable for 2-phase and 4-phase motors
    • Support PUL/DIR and CW/CCW modes
    • Short-voltage, over-voltage, over-current protections
    Servo Motor (3x)
    SY60STH86-3008 Nema 23 (Click for information) ($40.00)
    • Step Angle 1.8 Deg
    • Step Angle Accuracy 5% (full step, no load)
    • Resistance Accuracy 10%
    • Inductance Accuracy 20%
    • Temperature Rise 80OCMax.(rated current,2 phase on)
    • Ambient Temperature -20OC~+50OC
    • Insulation Resistance 100M Min. ,500VDC
    • Dielectric Strength 500VAC for one minute
    • Shaft Radial Play 0.02Max. (450 g-load) Shaft
    • Axial Play 0.08Max. (450 g-load) Max.
    • radial force 75N (20mm from the flange)
    • Max. axial force 15N
    420 dollar total What do you think of it?
    Thank you very much in advance =)
    Ps. I wish to add that I have quite some experience using CNC Cutters, laser cutter, prototyping & 5-axis machinery (however I can't program the last one on my own ). A few examples of past work:
    Feb 2008
    UK
    I ordered my Gecko 540 direct from Gecko for $299 + freight and had it within a week, 3x 3N steppers from the UK - were about £28/each - I know which I'd rather have!
    Mar 2009
    UK
    Buy the uniport straight from Roy the man who makes them, a little cheaper and a very help full man. http://www.diycnc.co.uk/html/uniport.html
  1. Need Help!- electronics
    By dreamci in forum General Electronics Discussion
    Last Post: 12-08-2010, 10:47 AM
  2. What electronics??
    By saddledance in forum DIY CNC Router Table Machines
    Last Post: 06-08-2008, 01:58 PM
  3. I need to know everything about CNC Electronics
    By alanfreefall in forum Servo Motors and Drives
    Last Post: 07-19-2007, 09:56 AM
  4. Electronics
    By Bassbuilder in forum General Electronics Discussion
    Last Post: 11-15-2004, 10:34 PM
  5. Electronics help
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 07-18-2003, 10:09 AM
