You'll get very poor performance with that Monster kit and 1/2-10 acme. If you use that motor/drive setup, you should use a screw with between 2 and 4 turns per inch. #60404 or #60986
Even if you went with the 4 turn/inch, you might get more speed out of the Sidestep package, unless you upgrade the Monster package to 42V power supply.
LinkBack URL
About LinkBacks
I've been obsessing and researching like crazy and here's what I'm currently thinking:
