Results 1 to 4 of 4
Thread: Motor/ballscrew ?
    Registered ne-oublie's Avatar
    Nov 2007
    Motor/ballscrew ?
    After sending out a couple of info requests on what to use for my router, i am having a hard time getting my head around motor size. I got a very helpful reply from John at Keling inc. Obviously he is far more knowledgeable than i in these systems, i am just having a hard time seeing how a Nema 23 387 oz motor with a 1/4" shaft, can drive a 25mm dia ball screw? The Y yes, but the X pulling the weight of the gantry etc. I just do not want to have problems from under powered motors, before i even get started. As i said he know these systems, so i am sure he is correct, this is what he recommended to me,
    http://www.kelinginc.net/ControlSystem.html
    KL-G540-48 4 Axis G540 CNC Stepper Motor Driver Controller $599
    Special Sale: $549.95
    4 pcs of 387 oz-in motors
    KL23H284-35-4B (1/4” Dual shaft with a flat) 387 oz-in
    http://www.kelinginc.net/NEMA23Motor.html
    Here is the link to the pics of my router i posted a while back.
    Another newbie, Another Machine, same old ????
    Any other info/advice/criticism, will be greatly appreciated, thanks.
    Graham.
    Jul 2008
    UK
    Graham,
    Take a look at the tutorial I wrote, it should give you some help... There is an excel spreadsheet (in post #2) but you'll need to convert from imperial to metric and back again...
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Nov 2007
    Thumbs up
    What a great write up, thanks. I will weigh the gantry this weekend and do some calculations, expect to hear from me
    Mar 2003
    Shelby Twp, MI....USA
    Be aware that the inertia of a 25mm screw may require much more torque to achieve rapid acceleration.
  1. Little slop in motor/ballscrew coupling ok?
    By brgrii in forum Linear and Rotary Motion
    Last Post: 09-03-2009, 08:10 AM
  2. Problem- Broken Motor to BallScrew coupler
    By IMK1230 in forum Syil Products
    Last Post: 01-05-2009, 09:29 AM
  3. Need Help!- pulley ratios : motor to ballscrew
    By circlecn in forum Industrial Hobbies (Support forum)
    Last Post: 09-13-2008, 06:32 AM
  4. Replies: 10
    Last Post: 01-16-2007, 12:27 PM
  5. ballscrew/ motor matches?
    By huios in forum Linear and Rotary Motion
    Last Post: 08-22-2006, 08:52 PM
