Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: pulling hair out
    Dec 2009
    uk
    Talking pulling hair out
    hi guys... I'm new to this hobby and have built a cnc machine... gone through all the pain like everyone else to precisly build this thing just so i can make a really big one, using this ugly one to cut the parts. Using mdf and ground rod for the axis's and steppers for the drives it was all going very well indeed..... fired up the thing got the x and y sort of running spent loads of time on the z axis as well. did a test where by jogged out a foot or so and it came back to precisly the exact spot... i couldnt believe it... so i thought lets tune the motors, watched the tutorial and went to work... now the y axis judders... the x and z axis make bad sounds cant seem to get the thing to go any faster..... put all the settings back, tried to eliminate play in the y axis but when i want to make the machine go faster it aint happening... you guys have heard all this before right?
    so you can help? please? please?
    Apr 2006
    na
    Quote Originally Posted by radioman View Post
    back off your setting in the motor tungng page to half the value u got them set and retune them ...sounds like you motors have maxed out ....what size are they what size of machine?
    Jan 2007
    Which turorial on tuning the motors/PID is that, and where did you get it?
    Thanks,
    Ian
    Dec 2009
    uk
    beginners stuff
    Thanks for your reply.
    I will take some pictures tonight and upload them. this will give you some idea to the size. I have already reinstated the original settings for the motors but it is awfully slow... going to take ages to cut anything.
    The turorial was on the artsoft USA website home of mach 3 in the tutorial section.
    Dec 2009
    uk
    got some pics
    got some pics how do i show them. chris.
    Mar 2003
    Shelby Twp, MI....USA
    Click the go advanced button than manage attachments
  7. #7
    Mar 2003
    Can you tell us the pitch of your screws, and what motors, drives, and voltage your using?
  8. #8
    Dec 2009
    uk
    sizes
    The threads are ..well i dunno but i can count 14 peaks per inch, the motors have the no. SY60STH86-3008BF on the lable they came from zapp ltd sold as nema 23... i have a stepsync controller (now no longer available i understand) it has chopper technology on it, and i have a power supply of 20v dc 10amp all running on mach3, by the way the nuts on the threads are crap i think they are just white nylon derlin... should i use ballnuts? cheers chris.
    here are some pictures.
    Attached Thumbnails Attached Thumbnails pulling hair out-dscf0263.jpg   pulling hair out-dscf0264.jpg   pulling hair out-dscf0265.jpg   pulling hair out-dscf0266.jpg
  9. #9
    Apr 2004
    Oakland CA USA
    The voltage sounds low
    Is 20v all your Stepsync controller can handle? Are you running them in unipolar or bipolar mode? They should be able to deal with more voltage; 25 times nameplate (3.9v unipolar for your motors) gets you to 97.5v. Most controllers will handle 50v or so, but check the specs on yours, if they're still available.
    Andrew Werby
    www.computersculpture.com
  10. #10
    Jan 2006
    I can't quite tell from the picture, but it looks like your motors are just sitting on those threaded carriage bolts. How are they attached? Those motors should be attached to those standoffs with a nut, at least. Looking at the pictures, it seems like they're being held on by the motor coupling. I could just be seeing things...
    Otherwise, it looks like a nice machine. I'm sure it will quite serviceable once you work out the bugs. We've all been there.
    Steve
  11. #11
    Mar 2009
    UK
    Check PM
    Radioman I Sent you a PM.
  12. #12
    Dec 2009
    uk
    Quote Originally Posted by stevespo View Post
    Steve
    the motors are bolted very firmly to the mdf in such a way as to minimise any backlash.
    there is still backlash so i suppose its virually impossible to build a machine out of mdf without it.
    chris.
  1. check that hair!
    By jp_dt in forum Safety Zone
    Last Post: 02-06-2013, 01:32 PM
  2. Sharpening Hair Clippers
    By ToyMaker in forum CNCzone Club House
    Last Post: 05-05-2009, 03:34 AM
  3. Need Help!- HAAS MINI MILL Question (I'm pulling my hair out)
    By Powder_Keg in forum Haas Mills
    Last Post: 09-19-2008, 10:09 AM
  4. 203V Pulling my hair out!!
    By WilliamD in forum Gecko Drives
    Last Post: 04-18-2008, 02:09 AM
