Results 1 to 9 of 9
Thread: V bearing model
    Jun 2009
    V bearing model
    I have been trying to design a DIy CNC and working with sketchup to do it. Im having a bear of time trying to draw a decent V-bearing. Has anyone done this or know where I can download a sketchup model of a V-bearing? Mine look like something a 3rd grader drew!!
    Thanks!!
    Jim
    Jun 2008
    Have you looked at http://sketchup.google.com/3dwarehouse/
    I did a search but found no v groove but lots of other bearing models that would be easy to convert to v groove.
    George
    Registered FandZ's Avatar
    Oct 2008
    As long as it is to scale why bother about the looks? But you want to use the follow me tool if you haven't already.
    Sketchups biggest downfall is curves though. I still love the program and use it religiously. If you want to give me the specs or a link to the bearings you plan on useing, I'll give it a go. I should be able to give you something you shouldn't be embarrassed by
    Oct 2005
    Thanks!!
    Jim
    Here is one that I drew in TurboCad 16 but save it as AutoCad 2004 Dxf. I don't think the materials and rending will save so you will have to do them in your cad.
    Its .375 (3/8) ID base on Dim form vxb.com
    Hope you are able to use it.
    Harold
    Attached Files Attached Files
    Oct 2008
    Quote Originally Posted by radcliffe View Post
    Harold
    I went ahead and converted it to a .SKP file and resized it cole to spec. For some reason sketchup had the inner diameter at over 4 inches
    I hope you like red jKootz
    Crap... Looks like cnc zone dropped support for .SKP files. That sux. ahh well.
    Oct 2008
    I hope you don't mind radcliffe, I went ahead and uploaded the on googles sketchup's website.
    http://sketchup.google.com/3dwarehou...40f3dfb56f75ab
    Mar 2003
    Shelby Twp, MI....USA
    Imported into Sketchup as a .3ds file. I drew some lines to locate the center for you.
    Oct 2005
    FRANDZ
    Here the same bearinig but in PDF Format.
    Harold
    Attached Thumbnails Attached Thumbnails V bearing model-v_bearing_pdf.pdf
    Jun 2009
    Wow I really appreciate the help guys, so fast to respond too!! Ive got a couple ideas in my head and want to get them down before I forget or get side tracked. Again....
    Thanks all!!
    Jim
    1. Bearing help
      By Bri4n in forum JGRO Router Table Design
      Last Post: 07-22-2009, 07:26 AM
    2. Bearing help Please
      By rodzilla in forum Linear and Rotary Motion
      Last Post: 12-17-2007, 04:05 PM
    3. Tapered roller bearing vs. angular contact bearing
      By boyvox in forum Linear and Rotary Motion
      Last Post: 01-25-2007, 03:49 PM
    4. Bearing
      By sala84 in forum JGRO Router Table Design
      Last Post: 11-03-2006, 10:42 AM
    5. Bearing in MDF
      By Photon in forum DIY CNC Router Table Machines
      Last Post: 05-20-2004, 05:18 PM
