Results 1 to 8 of 8
Thread: clamping methods?
    Jun 2009
    clamping methods?
    i tried to screw down the plastic im cutting, but it always seems to "bow" in the center while im milling. how are you guys keeping everything down?
    Mar 2003
    Shelby Twp, MI....USA
    My table has threaded inserts, so I bolt everything down. But a lot of times, you may find that different jobs require different methods. What kind of plastic, how big, and what kind of tooling are you using?
    Jun 2009
    1/8 acetal(delrin) 1/8" milling bit
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    what about giving it a dab of hot glue in the center to keep it from bowing , the hot glue can easily be peeled off later , i use hot glue to hold down nearly everything on my router table
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    Registered FandZ's Avatar
    Oct 2008
    Quote Originally Posted by dertsap View Post
    I've been useing hot glue to hold my parts down and while it works, I haven't been having a great time with it. If I put too little, then the part may come undone while being machined. If I put too much, it's like hell to get the part off the table. Do you have any tips on hot gluing you could share? I'm wondering if I need to run some kind of pull tabs under my stuck to make removing the pieces easier.
    BTW, I'm useing a lot of MDF.
    Oct 2005
    canada
    Quote Originally Posted by FandZ View Post
    a number of thin streaks usually do it for what I do , then I use a wood chisel and lightly tap and or slowly pry around the piece
    Oct 2008
    That worked. I was doing thick wavy lines with a big x from the corners. I just tried smaller straight lines in one direction and it was a lot easier to get off the table. Thanks
    Registered philly452008's Avatar
    Dec 2009
    UK
    I have used double sided carpet tape in the past(between table and sheet)and 2" wide masking tape to stick around the edges when machining 4mm thick perspex.Seemed to hold sheet adequately for my application,without the hassle of scraping off glue!Hope this may be of help.
    P.Penny@live.com
    1. Quoting - your methods?
      By Steve_T in forum General Business Practices and Pricing
      Last Post: 07-25-2012, 09:13 PM
    2. What deburring methods have you used?
      By cncwhiz in forum General Metalwork Discussion
      Last Post: 04-07-2009, 06:53 PM
    3. Test methods
      By guhl in forum Fanuc
      Last Post: 12-08-2007, 04:21 AM
    4. Replies: 12
      Last Post: 01-09-2007, 01:42 PM
    5. Better construction methods for my first machine...
      By karmicthre in forum DIY CNC Router Table Machines
      Last Post: 12-18-2003, 12:13 PM
