Results 1 to 7 of 7
Thread: flat belts, long lengths require
    Apr 2006
    na
    Hello im interested in knowing where to find, flat belts 1-1.5" wide that you can buy in a roll, as shown in this video, Thinking of using the concept to make waycover for my hiwin rails in the same way..... check out the the 1 min marker in the video.
    "http://www.youtube.com/watch?v=OdJoVh6DRPA&feature=player_embedded"]YouTube- ServoBelt: amazing belt drive
    Sep 2009
    You may like this site. I seen 1"w x 100' https://sdp-si.com
    Apr 2006
    na
    Quote Originally Posted by finder50 View Post
    i only seen 1/4 wide ?
    Dec 2004
    Barbados
    enter this part# A6R25MC250 - 25MM WIDE BELT HTD PROFILE 5MM PITCH
    A6T39MC250 - 25MM WIDE BELT "T" PROFILE 10MM PITCH
    Apr 2006
    na
    A6T39MC250 - 25MM WIDE BELT "T" PROFILE 10MM PITCH\
    thanks for the link, This stuff is not cheep lol $76.14 meter...have to find
    something abit more econical..... hmmmmm.
    Jul 2007
    If you are using it to make way covers, why do you need to use a toothed belt? Just get some upholstery strapping or some nylon webbing and use that.
    Apr 2006
    na
    Quote Originally Posted by rowbare View Post
    frist , doing traditon way covers will consum to much trail, secoundly you didnt watch the video did you? the belt will travel up and over the linear bearing.... nylon webing get so yucky after time......to much friction look terrible after few hundred hours of use. Also i want to machine 3/16 notch onto both sides of the the belt so it would seat in to a U frame perventing it from siding from side to side, which would hold the rail.
    Attached Thumbnails Attached Thumbnails flat belts, long lengths require-waycover.jpg
    1. Need Help!- Long timing belts?
      By Flibblebot in forum DIY CNC Router Table Machines
      Last Post: 06-20-2009, 09:31 AM
    2. CNC Belt Lengths
      By kingpav in forum Linear and Rotary Motion
      Last Post: 08-07-2008, 09:30 PM
    3. Anybody have any short lengths of 1.5 O-1 Drill Rod??
      By maxboostbusa in forum General Metalwork Discussion
      Last Post: 12-03-2007, 11:56 PM
    4. Joining Lengths of linear rail together..
      By hotponyshoes in forum Linear and Rotary Motion
      Last Post: 05-13-2007, 02:34 PM
    5. Belts to replace long ball screws? What are your thoughts??
      By runinbymdnt in forum Linear and Rotary Motion
      Last Post: 02-17-2007, 05:31 PM
