Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Spindle Motor
    Registered GAWnCA's Avatar
    Oct 2005
    Spindle Motor
    Well, I have to break down and ask for help. I picked up a CNC machine today and the problem is, the spindle is motor and belt driven. The motor that drives the spindle is 100 VDC 10 Amp. Finding a power supply is next to impossible, unless I want to take out a 2nd mortgage on the house. So I want to replace the motor with something in the 24 vdc range, 3000 rpm and the power supply to run it. Here's a couple of photos of the current set up. I was told the belt drive was 4:1. Thanks
    Attached Thumbnails Attached Thumbnails Spindle Motor-img_5513.jpg   Spindle Motor-img_5514.jpg
    Dec 2004
    Power supply too expensive???
    Quote Originally Posted by GAWnCA View Post
    If all you need is a way to run that motor and it is a pemanent magnet motor that should be easy.
    All you need is a DC motor drive. The drive takes in 120 vac 240 vac and output a DC voltage. The drives can also give a variable output voltage resulting in variable speed.
    I have several used ones made by Seco or there are other manufactures.
    http://cgi.ebay.com/DANFOSS-CYCLETRO...item3efa33dd4c
    Something like this should be what you are looking for.
    Many of them have analog input to allow programing the spindle speed form the CNC controller.
    If nothing else some of them have a pot on the front that lets you control the speed manually. If all you want is on and off, then just set the pot to max and leave it. The one that I have can give on and off plus speed control from the CNC controller.
    Let me know if this answers the question.
    Mike
    Oct 2005
    What is the amperage? Looks like it might work. Would be nice to control the speed from MACH3 as well. The guy I got the machine form had a power supply made by HP and he paid something like $350.00 If I can power this motor for your kind of price, I'll keep the motor that came with it.
    Mar 2003
    Shelby Twp, MI....USA
    You can also use something like this, I think,
    https://www.surpluscenter.com/item.a...tname=electric
    Dec 2004
    Nice find Gerry
    Quote Originally Posted by ger21 View Post
    That looks like it would do the trick as well.
    Mike
    Oct 2005
    Quote Originally Posted by TOTALLYRC View Post
    Mike
    Ok, I know this is an old thread but I could use some help, again. I got the Danfoss Cycletrol 150 DC Motor Control but can't figure out how to wire it up for the life of me. ANY help would be most appreciated. I can post photos of what I have if that will help.
    Dec 2003
    Do you have a link to the manual?
    Oct 2005
    Quote Originally Posted by Al_The_Man View Post
    No, I can't find much of anything on this and the wiring.
    Registered SScnc's Avatar
    Jun 2008
    See if THIS answers you question.
    HTH
    Oct 2005
    Quote Originally Posted by SScnc View Post
    HTH
    I've seen this but there's a lot left out of the schematic as to the wiring traces.
    Dec 2003
    The diagram seems fairly explicit, where is the confusion from?
    Oct 2005
    It may be for someone who is electronic oriented but not for me. Someone had re-wired the controller I have and none of the wires are where they appear in the photo. Maybe I can try to trace back and re-wire mine as it appears in the manual. There is a dead short between L1 and L2 as the wiring goes from L1 to the on/off switch through the light and back to L2. IF I am reading things correctly, the AC power should connect to L1 and L2 and the motor to L3 and L4.
    Attached Thumbnails Attached Thumbnails Spindle Motor-002-sm.jpg   Spindle Motor-004-sm.jpg   Spindle Motor-005-sm.jpg
  • Page 1 of 2 12 LastLast
    1. spindle motor and spindle control dont work
      By customcncparts in forum Milltronics
      Last Post: 10-01-2009, 03:08 PM
    2. a paper shredder motor for spindle motor??
      By .xXACEXx. in forum DIY CNC Router Table Machines
      Last Post: 06-02-2008, 10:17 PM
    3. Servo motor used as spindle motor?
      By fatal-exception in forum General Metal Working Machines
      Last Post: 09-14-2007, 03:55 AM
    4. more rpms for spindle motor and spindle
      By bob1112 in forum Mechanical Calculations/Engineering Design
      Last Post: 02-10-2007, 02:01 PM
    5. Spindle Motor
      By UKRobotics in forum General Electronics Discussion
      Last Post: 08-02-2006, 08:31 AM
