Results 1 to 7 of 7
Thread: How do you home an A axis?
    Registered FandZ's Avatar
    Oct 2008
    After I build my next Z axis, I'd really like to build a Z axis mounted 4th axis. I'm thinking in this situation it's called an A axis. Anyways, I'm sketching out some ideas but I'm stumped on how you would home it. Since it'll rotate left and right, I wouldn't be able to use the cheapo homeing lever switch I use now for my x, y, and z since as it would run over it. I've thought about a detachable hard stop but I'm sure something much better has been done.
    I've read through some 4th axis builds but I havn't seen anything about homeing it. Can someone enlighten me?
    Also I notice a lot of 4th axis's use servos and not steppers. Any particular reasons?
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    the magic of servos is the use of encoders
    what about using a proximity switch , this guy sells them pretty cheap http://cgi.ebay.com/CNC-Proximity-Li...4.c0.m14.l1262
    he's great to deal with , i've bought a fair bit of his stuff
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    FandZ,
    I use these on all my axis including the rotary, they work really well.
    http://www.hamlin.com/specsheets/591...;20IssueAc.pdf
    http://tinyurl.com/nn8bsq
    59140-040-ND
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2003
    Shelby Twp, MI....USA
    A push button switch with a two sided ramp to activate it. The ramp can go past the switch without damaging it.
    Registered amishx64's Avatar
    Jul 2008
    Quote Originally Posted by FandZ View Post
    Oh geez FandZ. What are you getting into now?
    Just kidding. Can't wait to see what you are up to.
    Oct 2008
    Thanks for the links and replies fellas. It was just one of those nagging questions that had to be asked. I guess what I'll do is keep designing it and use what ever fits the design best. Glad to know it doesn't have to be too much of an exotic solution.
    Oct 2008
    Quote Originally Posted by amishx64 View Post
    I think it's the natural progression of building a cnc. But you know me, always looking for new ways to use up this stock pile of skate bearings I have left over.
    1. Need Help!- EMC won't recognize home on Y axis
      By DustToDust in forum LinuxCNC (formerly EMC2)
      Last Post: 09-25-2009, 01:09 PM
    2. What is the gcode to ref 1 axis home after
      By seanreit in forum General Metal Working Machines
      Last Post: 12-07-2008, 05:18 PM
    3. Problem- Eztrak X axis will not home
      By sidstover in forum Bridgeport and Hardinge Mills
      Last Post: 11-11-2008, 08:04 PM
    4. Newbie- Z-axis 0 point (home) ?
      By tvdbon in forum DIY CNC Router Table Machines
      Last Post: 05-26-2008, 03:05 PM
    5. Z axis Home backoff
      By Stevie in forum Mach Mill
      Last Post: 12-20-2005, 06:28 PM
