Results 1 to 2 of 2
Thread: Limit switches...what do I need?
    Gold Member
    Sep 2004
    Hi Group
    I have the x axis of my cnc wood router complete. I `m hoping
    someone would be kind enough to give me some direction as
    to the requirements for the limit switches needed on such a machine.
    I`ll take a guess and say I need two limits per axis. Do the limits
    also act as homing switches or do I need say a proximity switch for
    the homing function of each axis. I`m using gecko drives and Bob`s
    breakout board.
    Thanks Barry
    Jul 2004
    Spring Hill, Florida
    Barry,
    The limit switches can either be done with 1 or 2 switches per axis. I use only one, which reads 2 flags, or you can use two and have them read 1 or 2 flags. I always try to use as little in the way of sensors as I can. Home is a different matter. You can use, but not recommended using your travel limits as a home switch. I use slotted switches or sensitive prox for home location. In most applications, home is not near (with the exception of the z axis) the end of travel. Switchs are cheap, easy to install and can be used in a configuraton to suit. Which ever one you decide on, order an extra one or two and keep as a spare. Hope this helps.
    Regards,
    Glen
  1. Help with limit switches and Xylotex board
    By dowling177 in forum Xylotex
    Last Post: 11-26-2008, 03:51 PM
  2. Limit switches
    By itsme in forum General Electronics Discussion
    Last Post: 05-01-2005, 06:02 PM
  3. The relationship of limit switches to home switches.
    By MikeAber in forum General Electronics Discussion
    Last Post: 11-04-2004, 02:28 PM
  4. Limit switches and home switches
    By viktorcnc in forum TurboCNC
    Last Post: 08-03-2004, 07:11 AM
  5. Home switches and limit switches.
    By ynneb in forum General Electronics Discussion
    Last Post: 04-08-2004, 06:32 PM
