Results 1 to 4 of 4
Thread: Acme leadscrew or Trapezoid leadscrew is better?
    Mar 2005
    TH
    Exclamation Acme leadscrew or Trapezoid leadscrew is better?
    Dear All,
    I plan to build desktop cnc. I choose leadscrew for 3 axis but between Acme leadscrew or Trapezoid leadscrew is better?
    Thank.
    Apr 2003
    UK
    I always thought they were the same thing, just that acme was the trade name. I would be interested in the answer!
    Aug 2003
    They are one in the same with regard to the shape and profile of the thread.
    The English measured thread is called "acme", see page 1557 of Machinery's Handbook #23.
    I don't know where the name "Trapezoidal" comes from, unless maybe that is what the metric countries call it.
    The shape, profile, and operation is the same.
    Patrick;
    The Sober Pollock
    Registered 10bulls's Avatar
    Feb 2005
    UK
    ACME is imperial measurements and measured in TPI, whereas trapezoidal is metric and pitch measured in mm.
    Looking at the following, they both have the same strength characteristics per pitch...
    http://www.kingston-engineering.co.uk/data/frame2.htm
    ACME also has a 29 degrees thread angle, trapezoidal 30 degrees.
  1. Leadscrew or Acme for Al. Router
    By js530 in forum DIY CNC Router Table Machines
    Last Post: 05-11-2005, 08:23 PM
  2. A source for 1/4 - 4 acme leadscrew? cheap of course!
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2004, 02:10 PM
  3. Acme leadscrew size selection info
    By jeffs555 in forum DIY CNC Router Table Machines
    Last Post: 06-13-2004, 10:31 AM
  4. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 08:24 AM
  5. Acme Tap
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-26-2004, 12:06 AM
