Results 1 to 2 of 2
Thread: pcb milling question
    Dec 2004
    I did a search and found out fr-3 is the recommended board, but who sells this fr-3 type boards?
    Is anyone doing double sided boards using the engraving method?
    I'm thinking about going single since it would be easier to start out with.
    I found some single sided boards on digikey, but I'm not sure what is a good choice on width, material, or type.
    http://www.digikey.com/scripts/DkSea...S&Cat=32375757
    Thanks for the help.
    Nick
    Feb 2005
    Ireland
    PCB laminate & Suppliers
    The standard PCB laminate is FR4 1.6mm. If you intend to mill out the tracks then you do not need the copper coated with photo-resist
    For higher currents you can use a thicker copper laminate but these are more expensive and take longer to etch. Soldering some wire to the track works just as well
    Cheaper PCBs pased on a paper glass mix are also available and are easier to drill eg CEM/1. While not as strong as FR4 they are easier on machine tools and drills and can also be punched.
    When drilling it is helpful to use a backing sheet of Alu foil coated SRBP board
    for the drill exit this helps prevent drill breakage
    For supplies you could try the us rep for Mega
    http://www.megauk.com/cgi-bin/mega/l...ww.megauk.com/
    http://www.vpcinc.com/Products/pcb.htm
    If you are interested in some background on commercial manufacture look here
    http://www.personal.dundee.ac.uk/~gjzcallo/
  1. Spindle speeds for PCB milling
    By CactusChip in forum General Metal Working Machines
    Last Post: 04-20-2007, 04:54 PM
  2. Milling Brass Question
    By djacob7 in forum General Metal Working Machines
    Last Post: 06-13-2005, 05:19 PM
  3. PCB milling
    By FabCNC in forum General Metalwork Discussion
    Last Post: 05-24-2005, 08:44 PM
  4. Just a question about plunge milling.
    By Machine1 in forum Hard and High Speed Machining
    Last Post: 01-28-2004, 09:36 PM
  5. Cutting tool shape for PCB milling
    By NeoMiller in forum General Metal Working Machines
    Last Post: 11-13-2003, 12:09 PM
