Results 1 to 4 of 4
Thread: cnc
    Mar 2004
    ms
    cnc
    how long of a rod can i use before i have to support it
    Jun 2003
    More information please. Are you talking to support the whole gantry, if so how much might it wiegh. How much rigidity do you require and what size rod (diameter) do you expect to use. Without this info we dont know if you're planning a desktop router or a 5' by 10' machine. The more information you can give the better.
    Mar 2004
    ms
    i have some thompson three quarter rod and pillow blocks they are 24 inches long i was wondering if i could build a cnc out of them i want use them on the x and y axis
    Jun 2003
    I'm confident it will work ok over 24 inches. If worst comes to worst you could make supports which would be mounted to the part of the rod diameter which is disused (between two of the three bearings which the gantry will run on) but I dont think you'll have any problems.
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 08-02-2010, 01:06 AM
  2. Making money with CNC
    By Johnuk in forum CNCzone Club House
    Last Post: 12-13-2009, 11:46 AM
  3. Newbie to CNC world
    By HighOctane in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 02:58 PM
  4. CNC deviation error
    By Alex S.A in forum General Electronics Discussion
    Last Post: 10-22-2004, 03:10 PM
  5. The start of a big CNC project...
    By UKRobotics in forum General Metal Working Machines
    Last Post: 09-30-2004, 06:34 PM
