Results 1 to 5 of 5
Thread: Moving or fixed Gantry ??
    Registered xairflyer's Avatar
    Nov 2003
    Ireland
    Just looking for views from people who have experience with both fixed and moving Gantry designs.
    I have always thought that moving Gantry increases the chance of movement in the Z axis for and aft.
    What are the pro's and cons of each version.
    Gold Member MrBean's Avatar
    Oct 2003
    UK
    For a very small machine, I'd go with moving table, as the bearings the gantry would ride on would take up a lot of the Y axis. If it's a larger design, then moving gantry's got to be the way to go. Imagine you want a cutting area of around X=4' * Y=6'. For moving table the Y axis would have to be double the cut required (12'). If you had moving gantry and the gantry bearings were say, 12" length span, then you'd need 7' for the Y axis instead of 12'
    That's how I view it.
    Regards Terry.....
    May 2003
    India, Mumbai
    Fixed & Moving Gantry
    Moving Gantry design is used for machines with large X-axis stroke. Normally the X-axis stroke should be beyond 10 meters or more.
    It also implies that the workpieces are large and heavy.
    In case of small machines, Moving Gantry design is used only in special cases like impeller machining etc. (usually 5-axis machines).
    If the Y-axis stroke is also large (say 5 to 6 meters), then the X-axis needs two ballscrews (two motors and two measuring systems) and a software to keep skew in control.
    smabhyan
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by smabhyan
    Or two screws mechanically linked and driven by one motor.
    Nov 2003
    Ireland
    I can see what your saying Terry fixed gantry machines have to be bigger to allow for the stroke of the table under the gantry.
    Iw ould think that for smaller machines (under 3ft square) then a fixed gantry would be easier to build and get set up.
    Don't think I would be too keen on a moving Gantry using the roller bearing method, but with linear rails to would be ok.
    1. Trade offs between Moving Gantry and Moving Table
      By gregmary in forum DIY CNC Router Table Machines
      Last Post: 04-22-2011, 02:48 PM
    2. Open Team Cheap DIY CNC Moving Gantry Router
      By pminmo in forum DIY CNC Router Table Machines
      Last Post: 08-19-2007, 02:59 PM
    3. Moving Table vs Moving Gantry; Dremel vs Router
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 03-27-2007, 09:48 PM
    4. Fixed Gantry
      By Auzze in forum DIY CNC Router Table Machines
      Last Post: 07-25-2004, 03:34 AM
    5. Moving Gantry Or Moving Table
      By DDM in forum DIY CNC Router Table Machines
      Last Post: 04-28-2004, 11:46 PM
