I was just wondering if any one has made the CNCZone Logo into a 3D Gcode, that they can upload for everyone?
This would be cool if we could cut a logo or sign and put it on out CNC Routers, What ya think?
Thanks, Joe
Thanks, Joe
HERE IS THE 3D FILE G-CODE (CNCZone![]()
) ENJOY IT
did anyone else get this to work? my router just cuts in a real tiny area, when i look at the code the x and y is close to each other.
thanks, joe
I looked at the code, it should be about 7" long.
I'd guess it will take a looong time to run. You might be stopping it too soon.
Why does it always move an axis twice in a row?
G1X0.0060F70.0
X6.9990
Y0.0052
Y0.0135
X6.9941
X0.0010
Y0.0176
Y0.0260
The file size would almost be halfed if it didn't do that. Sorry, but I have just never seen that before.
It's roughing at a 45° angle. In your example above, the router is just moving over for the next pass. It has to be that way.
I would love to see this machined out in alum, if anyone does it before me plaese post a picture of it.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
KellyCam chokes on the files. What is a good free viewer?
That is correct Ger21 is roughing a 45 angle
I will fix the code to make small size (cutting along axis Y )
This is going to take some serious machining time, I started on it for something fun, but gave up on the idea because I saw the machining times were going to be very long.
Here is the file in .XFA and .IGS if anyone can use them.
Ger,
Why would it not do the roughing parallel to the X or Y planes?Is there a benefit to going diagonal? Thanks.
Rance
Originally Posted by ger21
RANCE I made that way to get better finishing , anyway here is the updated g-code with roughing parallel to Y axis
let me know if this is better .
Anyone finish with the cutting please let us see the pic of it
thanks
