Results 1 to 12 of 12
Thread: CNC Router build
    Jul 2009
    Belgium
    Cool CNC Router build
    Hi There,
    I just had some first runs with my CNC Router.
    Here are some prelimary details, there is still a lot to do.
    Travels X=850mm, Y=500mm, Z=100mm
    Had a go at milling a PCB with insulation milling.
    Used a mill-bit I had available and without squaring the mill first.
    I was quite impressed with the raw quality.
    Controller is a Delta Tau PMAC-PC where I download the g-code into.
    PMAC's can run G-code by default.
    Regards,
    Attached Thumbnails Attached Thumbnails CNC Router build-dsc03663.jpg   CNC Router build-dsc03666.jpg   CNC Router build-dsc03667.jpg   CNC Router build-dsc03668.jpg
    Oct 2005
    Looks good.
    Jul 2009
    Belgium
    Rebuld in progress
    Hi ron22,
    thanks, mechanical is it quit simple but ofcourse not finished.
    Rebuild is in progress, new controller has been ordered.
    Old controllers is PMAC-PC ISA bus
    New controller will be UMAC Turbo2 with four axis analog controller.
    I will share more info when I have it.
    Regards
    Oct 2005
    Quote Originally Posted by Hersoft View Post
    Is there a reason you are switching to a Turbo? Or is it just because you want the UMAC?
    A turbo is more processing power than you need. I do like the UMAC package.
    Jul 2009
    Belgium
    Well the one and very important reason for me is that I like the inbuild g-code
    capabilities if the Delta Tau controllers.
    My original PMAC-PC controllers came from old Gen III Array Spotters which I could salvage. The Lowbow linear slides came from these too.
    I have some strange behavior seen from the PMAC board that I use, and my spare board has an older version of firmware on board.
    I had seen the UMAC systems on Ebay before but now it was a good opportunity and I went for it.
    Higher speed, more memory for the g-code programms and USB connection instead of ISA bus.
    Only thing is I have to convert my motor settings from PMAC to UMAC and this may take a little while.
    Are you working with Delta Tau systems yourself?
    regards,
    Oct 2005
    Converting motor setting from PMAC to Turbo2 (what is inside a UMAC) is not that hard. They did add more I varibles in the Turbo. There are some differacne becuase it is Turbo 2 (I assume your first was a PMAC 1)
    I work on Delta Tau systems all the time.
    Jul 2009
    Belgium
    Hello,
    Yes I have already made a complete backup of the old ISA PMAC-PC 1 board.
    I have to check the I-variables on both systems but at the moment I'm still waiting for the UMAC box to arrive.
    A question ,when I have the following configuration is there atleast one free output bit available to switch on/off the spindle motor?
    I was thinking of using the wachtdog output for this when possible (have to check manual)
    configuration is as follows:
    Computer Turbo PMAC2 USB - ACC-54E
    One ACC24E2A 4 channel board.
    and ofcourse power supply.
    regards,
    Oct 2005
    For an extra output map one of the unsed amp enable on the ACC24E2A to a M varible and use that.
    That is realy you only option for outputs with what you have.
    You could buy a I/O card on Ebay if you need more.
    Jul 2009
    Belgium
    I was afraid you where going to say that, an ACC11E is probably my solution.
    I was going to use the fourth axis for a rotary axis, but that can probably waity a bit.
    One thing I have to check is if I have an empty slot free for the ACC11E.
    I have only a 4-slot bus plane as far as I could check it.
    I still have to receive the box.
    regards,
    Mar 2011
    Lowboy motor control settings
    Hi there,
    I'm just working with a couple of lowboy stages, salvaged from the same spotter system... I've got the original motor drives, but as the controller was missing, I've opted to use a KFlop/KAnalog board (from Dynomotion)... While I do have the system operating reasonably well, I was hoping that I could trouble you for the PID values originally used in these machines? I realize they may not drop right in, but I'm hoping the original settings would give me a starting point to optimize the beast!
    Thanks so much,
    Brad
    Jul 2009
    Belgium
    Hi Brad,
    Great minds think alike don't they?
    I was lucky enough to be able to salvage the complete computer system also and that is how I got involved with Delta Tau controllers.
    I am in the middle of a rebuild of my attick and that is where my router is sitting normally. So at the moment it is not in operating condition so I can not check my PID settings in my Turbo Umac controller system.
    What I could find where my original Variables that I salvaged from the PMAC-1 board (included here)
    Hopefully You can extract the PID settings from there.
    I suggest you download the Turbo-2 manual from the delta tau website to get the descriptions for the I-variables. Then you can find which variables does what for the PID settings.
    With my set-up I am able to use the demo software from Delta tau to run G-code files with full support of the g-codes.
    drop me a mail when you need more.
    regards from Belgium, Otto.
    Attached Files Attached Files
    Mar 2011
    Hi Otto,
    Thank you so much - that really makes my day!
    Absolutely - the hardware out of those machines makes for a truly amazing motion system.... As long as you can make it work!
    No worries at all about finding your newer values - this is exactly what I was hoping for! I'll do some digging, and let you know how it goes.
    Thanks again,
    Brad
    (from across the pond in Canada)
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
      By Womble in forum DIY CNC Router Table Machines
      Last Post: 09-27-2008, 08:51 AM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
    4. Want to build CNC router
      By tc1 in forum DIY CNC Router Table Machines
      Last Post: 10-10-2007, 10:29 PM
