Is it just a belt reduction to turn a screw? If so, then the only issue would be inertia from a larger diameter. If the pulleys are heavy, than it would take more torque to accelerate at the same speed. If they are plastic, it probably won't make much difference.
LinkBack URL
About LinkBacks
