Results 1 to 2 of 2
Thread: Router is about finished! Now the next step.... using!!!
    *Registered User*
    Mar 2003
    marysville ca.
    After many months of building. I'm now doing power up testing to see if the Darn thing will work!
    I have been messing with Rhino3D and have some interesting parts modeled and have even developed some tool paths with RhinoCam.
    The next step is to join the machine and code with fixturing in between.
    Here are the questions:
    1. Seems to me once I have repeatable homing (I'm using proximity sensors and the accuracy remains to be seen). How may I best tell the system where the fixture and stock are? Is that the job for the G code editor.
    2. If assumption 1. is correct, is the general process to?:
    a. Define the path to a point of reference in relation fixture and stock? G code editor?
    b. Does it make sense to design the part and fixture simultaneously and with a x,y,z references embeded into the model.
    c. Is there any value to establishing a set of pre-established datums for all fixtures and using that geometry as a G-code subroutine that can be appended to part files for the purpose of semi automating machine setup for production. My guess is that fine zeroing and tool setting reference positions can be built into these subroutines!
    I realize I am asking for a LOT of info!!!! Comprehensive answers are not really what I am looking for, so much as strategies and tools that the experienced operator (youse guys) are using.
    I know I can fumble through this and cobble up a way! I'll bet there are many clumsy ways and an a much smaller number pretty elegant soultions. I would like to make good habits up front, as do we all.
    Thanks in advance!!!
    Mike
    Registered buscht's Avatar
    Nov 2003
    Quote Originally Posted by twombo
    It depends. In the simplest method, your home is always fixture zero and you don't have to worry about it. You simply draw the tabletop in your CAD program and always insert your part and fixture drawings on the tabletop (in CAD). For example, if the part is located 3" up in the Y and 3" over in the X, then the CAM program will output G Code that has and extra 3" added to all the dimensions. You just need a way to mechanically insure that the real part is located on the tabletop where you want it.
    Another way to do this is with the offset tables in your controller. Let's say you are using Mach 2. There are G code commands, G54, G55, G56, etc. that allow you to set up program zeros wherever you want on the table and call them up in the program. Once the offset tables are set up. (a one time deal if you never move your fixtures). You simply insert the appropriate G code at the beginning of your program. (Or better yet, set up your post processor to do it for you.)
    It will work either way, this question is a matter of preference and what type of work you are doing. I personally like to keep the part independant of the fixture.
    c. Is there any value to establishing a set of pre-established datums for all fixtures and using that geometry as a G-code subroutine that can be appended to part files for the purpose of semi automating machine setup for production. My guess is that fine zeroing and tool setting reference positions can be built into these subroutines!.
    Yes, that is what the G54, etc commands are for. On a well made machine, you shouldn't need much fine zeroing, tool setting is done with G code commands and another table for tool length and tool dia. No subroutines are needed.
  1. Finding The Right Router
    By Crushmonkey in forum Commercial CNC Wood Routers
    Last Post: 06-19-2006, 02:17 AM
  2. CNC Router with THK KR46 actuators Finished! pics & video
    By wisp in forum CNC Wood Router Project Log
    Last Post: 07-08-2005, 11:10 PM
  3. Finished CNC router tonight
    By snoman70 in forum DIY CNC Router Table Machines
    Last Post: 06-01-2005, 06:34 AM
  4. my new longbed router
    By cncspear in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 09:36 PM
  5. my second router just finished
    By trent2530 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2004, 11:55 PM
