Results 1 to 3 of 3
Thread: Lead screw pitch
    Jun 2009
    uk
    Lead screw pitch
    Another easy question for you guys,can I use different screw pitches for the 3 axis,if so where and how would they be programed in.
    Don
    Dec 2006
    Clw, FL
    Yes, you can use different pitch screws on different axis. In Mach3 go to Config>Motor Tunning, then you just figure out what steps to put there and you set, each axis/motor can have its own settings. For example on X you use 10tpi screws, with 200/rev motors with 10uStep drive, it would be 200x10x10=20000, or if 8tpi screw math would be similar, 200x8x10=16000 Hope this helps
    Jun 2009
    uk
    I'll say it helps,thank you very much,I will be using a metric pitch so I hope it can cope with it ok
    Don
  1. Variable pitch screw
    By ynnek in forum G-Code Programing
    Last Post: 08-06-2008, 09:13 PM
  2. Where can I find a 12mm 2.5 pitch lead nut
    By woodturn in forum Benchtop Machines
    Last Post: 03-14-2007, 12:17 AM
  3. What speed and pitch ball screw
    By George in forum Benchtop Machines
    Last Post: 01-08-2006, 01:14 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-15-2005, 09:42 PM
  5. Lead, pitch, start?
    By sixpence in forum DIY CNC Router Table Machines
    Last Post: 01-30-2004, 04:07 PM
