Results 1 to 3 of 3
Thread: chatter
    Feb 2007
    Cool chatter
    My home made cnc router is producing rough cut in wood always at the same spot ( 2 o`clock and 8 o`clock on a circle) the rest of the cut is nice and smooth.
    I suspect the width of my gantry could be the culprit, causing some binding when my router is working at both end of my Y axis.
    Is there a rule of thumb for the width of the gantry ?
    My table is about 2 feet on Y by 3 on X.
    May 2009
    uk
    Try a new sharp cutter
    Jul 2008
    Sounds like mechanical slop. See this post for pictures and solutions.
    http://www.mechmate.com/forums/showthread.php?t=1221
  1. V-Carve chatter
    By Xnaron in forum DIY CNC Router Table Machines
    Last Post: 04-21-2009, 08:29 PM
  2. chatter on bore out
    By kendo in forum General Metalwork Discussion
    Last Post: 12-16-2008, 09:26 PM
  3. chatter using mach 2
    By jtriggs in forum Mach Mill
    Last Post: 01-10-2007, 05:02 PM
  4. boring bar chatter
    By chipproducer in forum General Metalwork Discussion
    Last Post: 11-09-2006, 11:23 AM
  5. Chatter
    By gabeless in forum Hard and High Speed Machining
    Last Post: 07-14-2005, 12:09 PM
