Results 1 to 11 of 11
Thread: My new (and the first one :) ) CNC Router
    Sep 2008
    Croatia
    So here it is so far..it is my first build, and it is my own design..how do you like it?
    Attached Thumbnails Attached Thumbnails My new (and the first one :) ) CNC Router-cnc1.jpg
    Mar 2006
    I see a few areas that need to be dealt with but if you are doing light cutting it should be ok.
    Sep 2008
    Croatia
    Quote Originally Posted by SatanKlawz View Post
    tell me! what areas?
    I am going to cut only wood, balsa, ply...eventualy 2mm aluminum
    Sep 2007
    Quote Originally Posted by fly_kc View Post
    Congrats on completing your first machine! I'm currently in the midst of building my first. I am far from an exper but here are some issues I see:
    1) The gantry has not gusseting supports. These will prevent the gantry from rocking during heavy cuts. Also the gantry is very narrow; having a wider stance along the rails will help prevent racking.
    2) The rails are unsupported. They will flex slightly as the gantry rides over them causing possible chatter on heavier cuts.
    3) There is not work surface. Having a work surface will allow you to level the table to itself, allowing more accurate cuts.
    But overall, a GREAT first cnc. Would love to see a video of it in action if you have one. All of the points above are easily addressable in the future if you are not happy with the performance of your machine.
    Sep 2008
    Croatia
    thank you. it is not necessary to do all that because it is very solid as it is. Gantry is narrow, but it is really solid, because it is thick inox block (understand now? )
    Rails can't be suported because bearings "surrounded" the rail. I will make some photos when i dissasemble it for painting so i'll upload them here. i haven't tried it yet because i need monitor for pc that will be only for cnc (because on my netbook i dont have lpt) and power supply for cnc electronics.
    Sep 2007
    What material are you using for your rails?
    Sep 2008
    Croatia
    Quote Originally Posted by Spiv View Post
    stainless steel 17mm
    Sep 2008
    Croatia
    here it is
    Attached Thumbnails Attached Thumbnails My new (and the first one :) ) CNC Router-slika053.jpg   My new (and the first one :) ) CNC Router-slika072.jpg
    Mar 2009
    You're running it indoors? You either are single or have one understanding significant other. I would recommend getting quite a good dust control. First time I did a small cut in MDF in my garage I was shocked at the cloud of dust the thing produced and how it got everywhere. With a dust shoe, and Oneida cyclone, and shop vac it is not under control and the machine makes very little dust. But between the shop vac and router spinning, it is pretty loud.
    Sep 2008
    Croatia
    If you look better you can see model planes everywhere it is my "model room" in garage
    I still have to buy "chains" for cables..Oh, I mounted emergency stop button couple of days ago too..
    Aug 2009
    Have any more pictures of your bearing setup. It looks interesting and I cant really tell from the pictures.
    1. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
      By Womble in forum DIY CNC Router Table Machines
      Last Post: 09-27-2008, 08:51 AM
    2. Newbie- Does anyone own a EZ Router Machine? Plasma or Router.
      By sngatlanta in forum Commercial CNC Wood Routers
      Last Post: 04-11-2008, 11:48 AM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
    4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 09-23-2006, 04:33 PM
    5. Surfcam PP for Isel router / Precix router
      By IvanTochev in forum Post Processor Files
      Last Post: 05-12-2004, 01:27 PM
