Results 1 to 7 of 7
Thread: can a car scissor jack for a Z axis?
    Dec 2004
    I can get an XY from
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
    and the stepper / driver from
    http://www.hobbycnc.com/cncpackages/...g/4aupcpkg.htm
    That leaves my Z axis not finished.
    I was wonder if anyone has uses a car scissor jack for a Z axis?
    if anyone else has any cheap ideas, please let me know... I'm brain storming.
    Nick
    Registered JavaDog's Avatar
    Mar 2004
    There is a lot of play/backlash in a scissor jack.
    However, I wonder if the threaded-rod from a scissor jack, with a custom delrin/uhmw nut, would work?
    Aug 2004
    NickLaTech,
    PITS on Ebay has a larger table for about the same price. The cast iron is good the leadscrews are cheap.
    For headache less performance http://www.cnconabudget.com has an instant z-axis for around $200.
    Mar 2004
    Burnaby B.C.
    japanese car jacks are a good source for fairly reasonable acme screws
    if you only need a very short ball screw a manual steering box has one in it ( precision ground threads too )
    Registered Pythagoras's Avatar
    Dec 2004
    Austria
    The problem with scissor jacks are that you get more lift at the start of the winding and less at the end. The lift is not proportional the amount of turns along the thread. You would not be able to get your drivers to compensate for the variing proportions. Do you understand what I mean ?
    May 2003
    Illinois
    Dear Sir:
    As a good source of acme screws, consider Green Bay Manufacturing at 920-793-2411. They are in Two Rivers Wisconsin and make acme threads from .375-12 to 2.0"-4 so there is lots of range!
    Regards,
    Jack C.
    Jan 2004
    here is a pretty good unit.
    http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
    Only has about 3.5 inches of travel, and you would need to put a couple of slides on it, but other than that it is already built. Figuring out how to mount it to your machine could be tricky. Might have to have the router mounted sideways.
    Stop talking about it and do it already!!!!!
    1. 4020 4th axis problems
      By little bubba in forum Fadal
      Last Post: 06-13-2005, 10:08 PM
    2. No Encoder Counts On X Axis. Y=OK
      By murphy625 in forum CamSoft Products
      Last Post: 03-08-2005, 09:20 PM
    3. Where can I buy 4-5 Axis Wood CNC for making Car Parts ??
      By Calico in forum Commercial CNC Wood Routers
      Last Post: 02-27-2005, 08:21 PM
    4. 2 axis to 3 axis conversion
      By drembedded in forum Bridgeport and Hardinge Mills
      Last Post: 10-27-2004, 12:32 PM
    5. My Lathe project; might CNC it one day
      By Stevie in forum General Metal Working Machines
      Last Post: 06-21-2004, 09:27 PM
