Results 1 to 5 of 5
Thread: Stepper selection. Sorry I know I know
    Jun 2006
    I have been reading and doing calculation and I am still not satisfied with what I should get from Keling. I have a 100-130lb gantry that I want to mount 2 steppers on either side to drive it, rack and pinion. I want to cut at 3-500 IPM and rapid at 1000IPM at least. I was thinking about 2 of the NEMA 34 670oz/in motors. I would like to do it with no reduction if possible. What do you think?
    Mar 2003
    Shelby Twp, MI....USA
    What kind of resolution do you want, and what's the pitch diameter?
    Jun 2006
    .005 would be good or better and the pitch is 1".
    Registered johnmac's Avatar
    May 2007
    If you get your 100+ LB gantry that fast with a direct drive rack & pinion setup, how are you going to get it stopped? Will you have a problem with the momentum of the gantry trying to overrun the steppers? My gantry is about 150 LB, but I have a ball screw that acts as a brake.
    John
    Registered jsheerin's Avatar
    Aug 2008
    Your motors slow the gantry down by applying torque in the opposite direction they did to accelerate it. It should take the same torque to stop as to start. Actually it would take a bit less, as drag would help it stop. So if you have an acceleration value that works for speeding up, it should work for slowing down as well.
    1. Stepper motor selection for a wheelchair-urgent
      By kiceng in forum Stepper Motors and Drives
      Last Post: 03-12-2009, 04:08 AM
    2. Newbie- stepper motor selection
      By dextronfleet195 in forum DIY CNC Router Table Machines
      Last Post: 03-12-2008, 10:05 PM
    3. X2 Stepper Motor Selection
      By dleroi in forum Benchtop Machines
      Last Post: 09-18-2007, 12:56 AM
    4. Stepper Motor Selection
      By dberndt in forum Stepper Motors and Drives
      Last Post: 12-06-2004, 07:50 AM
    5. Motor selection advise needed? Servo or Stepper
      By Beezer in forum DIY CNC Router Table Machines
      Last Post: 03-21-2004, 01:24 PM
