Page 3 of 3 FirstFirst 123
Results 25 to 26 of 26
Thread: First build! 3-Axis Gantry-style CNC
  1. #25
    Registered ahren's Avatar
    Feb 2004
    Jack,
    I wouldn't worry too much about your motors and power supply. A "lack of voltage" for stepper motors isn't that big a deal until you get to high speeds. It does affect how fast you can go, as the voltage you run at is basically the voltage available to overcome back-emf as the motor runs faster. However, it has no influence on low-end torque provided you're several times above the motor's rated voltage. At 36V, you aren't losing too much.
    Bakachan, your wiring job does look good. I wouldn't worry about the amperage a D-sub can take. While it may have a rating of some sort, the distance the current is traveling through the connector is very short, so you shouldn't see much voltage drop (or much in the way of heat). What I would worry about is the extension cables you build for the motors. Make sure these are sized properly, especially if they are longer than 3 or 4 feet. For 3.5A of current, you should be using at a minimum 24 AWG wire, and these will warm up (and lose power for your motors). 22 or 20 AWG is preferred, and required if you are pulling more current.
    Ahren
    www.cncrouterparts.com
  2. #26
    May 2008
    Quote Originally Posted by ahren View Post
    Yeah, thanks for the tip, I tried to look for guidelines on what gauge wire I should run, and ended up sort of defaulting to going by what the leads on the motor were; 22 AWG. And the shielded multi-conductor wire I'm using is 18AWG. I was hoping for 20 or 22 to keep the bulk down, but the place I was getting it from only had 18 AWG for that, and 22 AWG for the shielded limit switch wire.
    Speaking of the limit switches, I mess around with a lot of microswitches, because one of my other hobbies is arcade hardware. But I decided to do something interesting with the switches when I came across a neat switch on Digi-Key.
    Omron makes these nice low-profile chassis mount microswitches in any combination of NC/NO, roller/simulated roller/no roller/no lever, but instead of having terminals on them for disconnects or the like, they have a tiny locking plug. I'm just a huge nerd when it comes to elegant solutions, and so I had to get them. :P
    So far it's been a total FLOCKING BUSTARD crimping the pins for the connectors though, despite having a MOLEX pin crimping tool. They're just so tiny! But I'll persevere!
  1. RFQ Z Axis Gantry style router
    By Jan-Roger in forum Employment Opportunity
    Last Post: 07-31-2006, 11:24 AM
  2. Overtable gantry style?
    By Dongle in forum Mechanical Calculations/Engineering Design
    Last Post: 03-09-2006, 10:57 AM
  3. Gibbs and a gantry style router
    By bgolash in forum GibbsCAM
    Last Post: 12-18-2004, 01:24 AM
