Results 1 to 3 of 3
Thread: printer port to usb
    Sep 2004
    canada
    printer port to usb
    ok.....now bare with me, I hope this isn't too dumb of a question, but....is it as simple as buying an adaptor for printer port to usb to have the boards work off usb instead of the printer port? Just that desk tops are coming out without a printer port and I have a newer laptop that also doesn't have a printer port. If so can anyone recommend a good adaptor? One last question, I am looking for a 4 axis board(complete) that is already built and ready to go. I am hoping to get some advice from some of you to which one I should be looking at. Of course money is always the key factor here as well as shipping. I live in Ontario Canada and don't want to pay an arm or a leg for shipping. So basically, which one out there is my best bang for the buck.
    Mar 2003
    Shelby Twp, MI....USA
    USB to parallel adapters do NOT work. You can always add a PCI parallel card. Laptops don't always work well for CNC applications.
    The best 4 axis drive is probably going to be the Gecko G540.
    Oct 2008
    United Kingdom
    If you're happy to just use Mach 3, then the Smoothstepper does a neat USB to parallel conversion, and adds lots of useful functionality, too, like independently generated pulse streams for the steppers, that don't rely on the PC or laptop generating evenly timed pulses.
    Here's a link:
    http://www.warp9td.com/
    Jeremy
  1. Printer port problems
    By tehMadmachinist in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 10:10 PM
  2. USB to Printer port compatability
    By CbrViking in forum Mach Mill
    Last Post: 02-27-2007, 06:05 PM
  3. printer port tester
    By smarbaga in forum General Electronics Discussion
    Last Post: 12-10-2005, 12:57 PM
  4. Communications output to Printer Port
    By kheri in forum Post Processors for MC
    Last Post: 03-26-2005, 01:40 AM
  5. printer port?
    By replicapro in forum General CAM Discussion
    Last Post: 11-26-2004, 04:37 PM
