So Terry,
After having watched it, I'd say that if you have enough Z travel, I'd highly recommend that you shorten up your collet grip on that tool. It'll be a lot less buzzy if you do. Maybe get ahold of a ball end mill, without the hugely undercut shank, too, which will help with the stability of the tool's tip.
Whats the difficulty you're having with drilling the holes?
LinkBack URL
About LinkBacks
