im looking for planarty gears, that would fit a nema 34 motor, need 10:1 ratio
or so... Looking for any leads or tip where to source them cheap...
Ebay. But good ones are typically not cheep. Plus have to watch about the input and output shaft sizes. That is sometimes more dificult to sort out. If the one you get does not fit your motor the proper size part is expeincive (from Thompson for example if I needed to get a different input shaft adapter it would be 200+ bucks for my planetary). Although I did get my 10:1 micro thompson planetary for only 79 bucks from a guy on ebay. Although I was both luckey and took many weeks of watiting to get the right one. I do hope I never have to replace it since I probably will not get one that cheep next time around.
b/
