Results 1 to 5 of 5
Thread: Real quick Gecko/stepper question
    Registered idtkid's Avatar
    Feb 2007
    Im afraid that by running THESE #RS34-960 motors off of a Gecko G540 that they will need to draw more current than the G540 can output is this true? Thanks so much for your help!
    Mar 2003
    Shelby Twp, MI....USA
    Motors can't draw more current then the drive can handle. The drive regulates the current.
    Apr 2007
    Quote Originally Posted by ger21 View Post
    True, but what he said was "they will NEED to draw", not they WILL draw.
    Do the calculations to see what their current and voltage needs are and then you can determine if the G540 is appropriate.
    Feb 2007
    Yeah guess that does make sense :P thanks!
    Mar 2003
    You can wire them bipolar series at 3.5amps, or run them bipolar parallel at 3.5 amps, which would give you roughly half their rated torque, as torque is roughly proportional to current. For best performance you'd want to use A Gecko G201, 202, or 203.
    1. Gecko G540 Quick question
      By mad_dog096 in forum DIY CNC Router Table Machines
      Last Post: 01-02-2009, 10:06 PM
    2. I'm going to ask a real pointed question
      By PBMW in forum Haas Mills
      Last Post: 04-02-2008, 11:04 PM
    3. Quick Question on stepper motors
      By cspearsall in forum Open Source CNC Machine Designs
      Last Post: 06-28-2006, 06:51 AM
    4. quick stepper electronics question
      By keebler303 in forum General Electronics Discussion
      Last Post: 03-31-2006, 08:40 PM
    5. Real stupid question
      By lsippell in forum General Electronics Discussion
      Last Post: 07-22-2004, 10:11 AM
