Results 1 to 6 of 6
Thread: wanted Pictures of Controller Cabinets
    Apr 2006
    na
    im looking for some inspiration on some design layout for my power supply and break brd layout,,,
    Does any know of some good links here cnc zone for a clean small really thought out compact design.
    Apr 2006
    na
    Registered port_huon's Avatar
    Dec 2007
    Here's one that's worth a look.
    (Not sure if you have to be a member of the forum to view pictures.)
    Regards
    Geoff
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Hi eloid,
    Attached you'll find three photos of the electrical box for my small machine. Three G210's, 45V powersupply, 24V auxiallry powersupply, opto-isolators for limits and homeswitches and a F/V converter for the spindle VFD. There's more stuff in there than initially planned so it's a bit crowded - works good though so I rarely need to mess with it.
    I've also attached a photo of my current project, it's a lot larger project and is still work in progress. 3 HP-UHU drives, 130V 4kVA powersupply with softstart and regenerative powerdump, 5.5kW VFD, C11 breakoutboard and Smoothstepper. I still have a few small things to do on this one before mounting it in the cabinet and closing the cable conduits.
    Attached Thumbnails Attached Thumbnails wanted Pictures of Controller Cabinets-electronics_002.jpg   wanted Pictures of Controller Cabinets-electronics_003.jpg   wanted Pictures of Controller Cabinets-electronics_front.jpg   wanted Pictures of Controller Cabinets-cimg0325_resize.jpg
    Apr 2006
    na
    nice layout..
    your new control panel is intense...
    I too am planing on using the smooth stepper and the same break brd...
    do you have a schematic to share, Im still new to the hobby and its my frist
    machine,,,, not 100% clear how to wire estop circuit and limit switchs
    can you post it or let me know i send you my email address
    H.O
    H.O is offline
    Jul 2007
    Sweden
    The system is quite complex with a PLC comunicating with Mach3, an encoder-interface between the encoders and SS so that the SS keeps track of position even during E-stop, soft-start, regenerative powerdump and so on. The schematic is over 20 pages at this time and I still haven't finished the home and limit switches...
    How to wire the E-stop and what to do depends on what kind of machine you have. Generally you want the E-stop to cut power to the machine. You should NOT rely on the software for E-stop control, you should hardwire the E-stop switch, generally thru a relay or contactor so it cuts power to the machine. Then you can use a second contact to "inform" Mach3 that you have E-stoped.
    1. How'd you supply your power supply?
      By cnczane in forum DIY CNC Router Table Machines
      Last Post: 08-28-2011, 06:13 AM
    2. power inverters/g-10 breakout boards
      By m8kingit in forum General Electronics Discussion
      Last Post: 01-30-2009, 08:19 PM
    3. Breakout board - power light indicator?
      By MakotoKamui in forum Automation Technology Products
      Last Post: 03-24-2008, 12:45 PM
    4. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
    5. Need a breakout board that can supply 25ma
      By damae in forum General Electronics Discussion
      Last Post: 07-13-2005, 12:48 PM
