Results 1 to 4 of 4
Thread: shaft couplers do i need
    Oct 2004
    Hello i was wondering if i need flexible shaft couplers from the motor to the lead screw if both ends are suported on pillow block bearings the longest screw would be 30 inches
    Registered buscht's Avatar
    Nov 2003
    I suppose it depends on how accurate your machining and mountings are. I always use flexible couplers as it makes this part of the job easier.
    Mar 2003
    Shelby Twp, MI....USA
    If the alignment is not absolutely perfect, you could have some binding with out them. Flexible couplers allow for slight misalignment.
    Oct 2004
    Hey thanks Guys i will instal them for sure .
  1. Shaft Whip
    By thielert in forum DIY CNC Router Table Machines
    Last Post: 03-29-2006, 12:29 PM
  2. mounting flexible couplings to 17mm shaft
    By cowanrg in forum General Metalwork Discussion
    Last Post: 04-11-2005, 01:40 AM
  3. Thompson Shaft and bearings flex help?
    By foamcutter in forum DIY CNC Router Table Machines
    Last Post: 04-24-2004, 05:24 PM
  4. My huge shaft!
    By kong in forum DIY CNC Router Table Machines
    Last Post: 08-29-2003, 01:54 PM
  5. Drilling hardened steel shaft
    By Zephrant in forum General Metal Working Machines
    Last Post: 06-13-2003, 04:42 PM
