Results 1 to 4 of 4
Thread: Need advice on router mount
    Aug 2003
    I have a Makita (Model RF1101) that I am trying to attach to my newly made Z-axis. Should the mount be aluminum or can I use plastic? I was thinking about a 1/2" thick white plastic butcher-block I have. There is enough material to make 2 or 3 mount rings.
    What I had in mind was simple:
    1. Cut three 4.5" squares.
    2. Cut a circle exactly 3.22" in diameter in each square. (The diameter of the router.)
    3. Drill some long bolt holes through the sides of the squares.
    4. Then cut about 1/4" from each of two sides. Now you have 2 peices for each square. Like this: |( )|
    Then I should be able to stick the router between the 2 halves of each square and and hold it together with the long bolts which will thread into the metal base plate.
    I don't have access to a cnc mill/router and don't have the money to have a part made. I was just wondering what you thought of plastic for a router mount. Should I wait and do it in aluminum? Anyone else use plastic for this?
    Registered JavaDog's Avatar
    Mar 2004
    Here, I knocked up a file, dimensions are accurate to your scale. I think this is the way most do it (seems the easiest):
    (A Translucent head-on view for clarity. BTW - I messed up, you don't have to make that hole go through the entire block, but I did this in 5mins, so you get the general idea).
    sol
    sol is offline
    Gold Member
    Sep 2003
    My first one was of wood,shaped like your idea and worked well enough; keeping the through-bolts tight is what mostly holds the thing true anyway. If it turns out to not hold up well at least you will have a template for the final metal version.
    JavaDog's rendering is nice but I think your idea of through-bolts holding semi-circles together and to the back plate is better for a non-metal clamp. Strength will come from the bolts not the plastic.
    I used big honkin' wing nuts on the through-bolts to tighten the assembly together and made inserts of wood and PVC that held a Dremel inside the larger router clamp. That way it was easy to quickly switch out routers when a powerful (noisy) spindle was not necessary.
    Like I said, worked for me.
    Oct 2004
    Another very helpful drawing for us newbies! Thanks JavaDog. Thought I'd give it a bump. Any explanations on parts especialy drawings are very helpful. Thanks!
  1. Router Mount
    By wired in forum DIY CNC Router Table Machines
    Last Post: 09-29-2005, 09:08 PM
  2. Porter Cable Router Motor Mount
    By dowling177 in forum DIY CNC Router Table Machines
    Last Post: 04-04-2005, 08:40 PM
  3. RFQ - Makita Router Mount Bracket
    By samualt in forum Employment Opportunity
    Last Post: 01-26-2005, 12:43 AM
  4. Router Motor Advice Please
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 11-03-2004, 02:49 PM
  5. Need some advice on DIY 24"x24" CNC Router Table...
    By kanankeban in forum DIY CNC Router Table Machines
    Last Post: 06-01-2004, 07:38 AM
