Hi all, I'm in the early stages of my first cnc design and one of many builds that have inspired me is this one http://www.glacialwanderer.com/hobbyrobotics/?p=17
Anyways, I really like his axis but I'm trying to cut corners where I can. I started thinking and came up with the design below. (someone else must have also come up with this also. If there is a writeup please link me.) Basically I'd be using angle rolled steel, skate bearings, flat rolled steel, nuts, bolts, and washers to create Linear rolling axis. What I like about it is the cuts don't have to be precise; just the wholes to be drilled on a drill press. Just rough calculations you could have all your axis for under $50.
Please let me know your thoughts. Please forgive the roughness of the pictures. They are by no means to any sort of scale or precision. I haven't even made all the necessary wholes and whatnot's. Just enough to convey the idea, hopefully. It was one of those spur of the moment ideas gathered on the john...lol
LinkBack URL
About LinkBacks
